jsalicru Posted July 29, 2006 Share Posted July 29, 2006 I had an interesting find today. I've been living with the nastiest of leaks for some time now on my UP (or I assumed my UP at the time). It seemed a little odd because it sprung up some 2 months after I installed it. I've had random problems ever since I installed my Perrin headers. RIGHT after I installed them, the heatshield broke loose from the UP... so to remedy it, I decided to take the heatshield off. Aparently this was not a good idea. My UP BROKE in the flex section. Out of plain coincidence, I had socalsleeper's Crucial UP sitting here in my garage and to top things off, he stopped by to help and keep me some company. Well, his UP is now on my car http://web.mac.com/jsalicru/iWeb/CarPages/Up%20Failure_files/IMG_2886.jpg One more thing... keep a good eye on the oil feed banjo bolt.. we found mine leaking (I have never touched it). "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
SnoDork Posted July 29, 2006 Share Posted July 29, 2006 so do you contribute your STI uppipe failing/breaking to the fact that you removed the heat shields? you think your STI uppipe would of failed if the heat shields stayed on?? ~Sucka-Duck~ Link to comment Share on other sites More sharing options...
legacy_y_tu Posted July 30, 2006 Share Posted July 30, 2006 Could you hear the leak or were you noticing low boost levels? <<< Has the STI pipe Link to comment Share on other sites More sharing options...
jsalicru Posted July 30, 2006 Author Share Posted July 30, 2006 so do you contribute your STI uppipe failing/breaking to the fact that you removed the heat shields? you think your STI uppipe would of failed if the heat shields stayed on?? I'd say it happened due to the removal of the heatshields. They act as a support to a certain extent. "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
jsalicru Posted July 30, 2006 Author Share Posted July 30, 2006 Could you hear the leak or were you noticing low boost levels? <<< Has the STI pipe Oh, it sounded like the leak from hell. It started out as something small and worked it way to a large leak within a week's time. "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
jsalicru Posted July 30, 2006 Author Share Posted July 30, 2006 Pics are up "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
jsalicru Posted July 30, 2006 Author Share Posted July 30, 2006 ..... "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
StealthGT Posted July 30, 2006 Share Posted July 30, 2006 taking that heat shield off must have been a bitch Link to comment Share on other sites More sharing options...
jsalicru Posted July 30, 2006 Author Share Posted July 30, 2006 taking that heat shield off must have been a bitch Yeah, its certainly something I wouldn't wish on anyone to have to do. "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
FONTANA MOTORSPORTS Posted July 30, 2006 Share Posted July 30, 2006 my banjo bolt was slightly loose after i installed my uppipe, must be from the slight movement when replacing it Link to comment Share on other sites More sharing options...
CobaltForge Posted July 30, 2006 Share Posted July 30, 2006 Wow that sucks. I hope this doesn't happen to mine, but I didn't bother to remove my heatshields. OTOH, glad the Crucial worked out? Was this install a PITA? Link to comment Share on other sites More sharing options...
al-gorithm Posted July 30, 2006 Share Posted July 30, 2006 Mine were removed but I didn't have a leak. I had my welder do it though. He may have touched up a weld or two. I had it ceramic coated right after and haven't had a leak. Link to comment Share on other sites More sharing options...
sgt Posted July 30, 2006 Share Posted July 30, 2006 I cant imagine the heat shields offering that much support Link to comment Share on other sites More sharing options...
al-gorithm Posted July 30, 2006 Share Posted July 30, 2006 Probably a common weld location. Welded the heatshield on to an existing weld on the pipe. Link to comment Share on other sites More sharing options...
jagcars26 Posted July 30, 2006 Share Posted July 30, 2006 Thanks fr the heads up,, << has the STi upipe with heatshields in place. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted July 30, 2006 Share Posted July 30, 2006 First I've heard of this. Flex>rigid. Link to comment Share on other sites More sharing options...
jsalicru Posted July 30, 2006 Author Share Posted July 30, 2006 Wow that sucks. I hope this doesn't happen to mine, but I didn't bother to remove my heatshields. OTOH, glad the Crucial worked out? Was this install a PITA? Installation was smooth for me. No real issues.. took the time to torque things twice, but everything seemed alright. I don't think I told you about psucaptainkickass.. the leak.. was all in his head.. the Crucial NEVER leaked "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
CobaltForge Posted July 30, 2006 Share Posted July 30, 2006 ^^^ Good to know! Glad the Crucial worked out! Link to comment Share on other sites More sharing options...
Bigltfp Posted July 31, 2006 Share Posted July 31, 2006 I had the STI UP on my REX for 2 years. The heatshields are a notorius source of rattles. The HS's on my UP were loose to the point that they could be moved up and down by hand. After I went in for a catless DP, I had my guy weld the HS's back in place. Well within a month they were loose and rattling again. I drove the car like this for over 2 years (so annoying) Well now I am having them removed now that it's going on the LGT. Since I drove for so long with the HS's loose, I can't imagine that they offer any stability to the pipe. It was probably just your pipes time to fail The only thing I could think of is if water might be able to get right on the UP when it's real hot and affect it in some way... LG Link to comment Share on other sites More sharing options...
jsalicru Posted July 31, 2006 Author Share Posted July 31, 2006 ^^^ Its true. My old STi has a loose UP heatshield and I'm guessing its been like that for a couple of thousand miles. I had this intermittent rattle when I had it and they new owner would get it too.. when I installed a TBE on the car a couple of weeks ago I shoot it around and sure enough, it was loose.. the funny part is that it hasn't rattled again... even though its loose. You are right though, it simply could have been my pipe's time... also, like I said, I started having issues with it the moment I started the car with the Perrin header. "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
