DaveZ Posted July 27, 2006 Share Posted July 27, 2006 Hey folks, I like my (non GT) 06 Legacy sedan, but it does have more roll than I'd expect when pushing it a bit. I've received 3 messages for dealing with this: - sway bars - springs/lowering - tires The tires are Yokohamas, not the R92s. What I'm reading is without lowering, bigger sway bars might break the mounts (due to all the force being applied). What do you think? Start with lowering? Just springs, or are struts par tof the fix? A local shop said, springs only, their kit would lower by 1.4" which seems a bit excessive. And, what does Subaru think about aftermarket suspension? Would it void the warrantee? Link to comment Share on other sites More sharing options...
dan_m Posted July 27, 2006 Share Posted July 27, 2006 I don't think aftermarket sways would affect anything, lowering springs would void your strut warranty on-da-spot Link to comment Share on other sites More sharing options...
leftride Posted July 27, 2006 Share Posted July 27, 2006 it will void that part if it breaks it, but they have to prove that the part broke it. *vb gallery* Link to comment Share on other sites More sharing options...
chenc544 Posted July 27, 2006 Share Posted July 27, 2006 Cobbs' ASB comes with re-enforced mounts. Link to comment Share on other sites More sharing options...
DaveZ Posted July 28, 2006 Author Share Posted July 28, 2006 Hm well, guess I'll make do until 3/36K are up. Still a fun car to drive. Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted July 28, 2006 Share Posted July 28, 2006 Cusco Sways FTW If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
Guest Posted July 28, 2006 Share Posted July 28, 2006 Get JDM GT Subaru bar. They can' tell you it's aftermarket! ;-) Link to comment Share on other sites More sharing options...
ebpda9 Posted July 28, 2006 Share Posted July 28, 2006 or yopu can have the front camber set at -.75 degrees. did that 2 days ago and the car handles like a dream. even the body roll in turns is reduced drastically Link to comment Share on other sites More sharing options...
OhBe1 Posted July 28, 2006 Share Posted July 28, 2006 How would camber affect roll? I can see that increased camber would increase grip, & higher lateral Gs would increase roll... 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
