mudcruiserman Posted July 20, 2006 Share Posted July 20, 2006 I have an 05 2.5i NA and want to put 225/40/18 on some 18x7.5 OZ wheels used off a 05 GT. A mechanic friend of mine said some tuner kids he knows put these on other cars ands ended up with excessive wear on the inside edges. I never heard of this with Subbies. Any Info. Link to comment Share on other sites More sharing options...
Hanger Posted July 20, 2006 Share Posted July 20, 2006 i have a 2005 NA and currently running on 225/40/18 on 18x7 wheel for about 7k miles now.. i haven't seen any abnormal wears on my tires... you'll be fine! ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
93formula Posted July 20, 2006 Share Posted July 20, 2006 I had some on my front, I raised the pressure and they seem to be wearing fine now. Link to comment Share on other sites More sharing options...
Xenonk Posted July 20, 2006 Share Posted July 20, 2006 because of the positive caster, the more you lower the car and the more you have negative camber, the more you get toe-out which toe is what wears your tires. As for just swapping to similar overall tire diameter sizes, you'll be fine.. it's when you run undersize or oversize of what your original alignments were designed to do. Keefe Link to comment Share on other sites More sharing options...
