Repsak Posted July 16, 2006 Share Posted July 16, 2006 Can you change the auto ac climate control and radio on 06 gt's to the 2.5i non auto climate control and radio? Im thinking you can but it might mess up the computer? Link to comment Share on other sites More sharing options...
lucas569 Posted July 17, 2006 Share Posted July 17, 2006 ibtl Link to comment Share on other sites More sharing options...
gfxdave99 Posted July 17, 2006 Share Posted July 17, 2006 Can you change the auto ac climate control and radio on 06 gt's to the 2.5i non auto climate control and radio? Im thinking you can but it might mess up the computer? NO If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
Repsak Posted July 17, 2006 Author Share Posted July 17, 2006 woah easy there guys, i searched it and didnt find too much on it.. Link to comment Share on other sites More sharing options...
gfxdave99 Posted July 17, 2006 Share Posted July 17, 2006 http://legacygt.com/forums/interior-audio/19855-can-2-5i-non.html?highlight=controls+swap+auto The simple answer is no, i wasnt being rude. If you want more details check out this post. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
Repsak Posted July 17, 2006 Author Share Posted July 17, 2006 thank you. Link to comment Share on other sites More sharing options...
Hanger Posted July 17, 2006 Share Posted July 17, 2006 even if you could, it'll be so much work -.- ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
IanKen Posted July 19, 2006 Share Posted July 19, 2006 I asked around. The dealer just flat out said "no." Then I went to a guy I trust. He spent about a week burried in subie tech manuals. His guesstimate is about $1200 to do it. That's a GUESS based on his research. The heater box would need to be replaced as it is unique to the dual zone setup, a wiring harness made and the control module for the "manual" system ordered to replace the dual zone control module. The only reason he bothered to do the research is because the dealer said it was impossible. It is not impossible, just impractical. Will I get it done? Dunno. The idea is certainly atractive but $1200 is a bit steep for somthing that solves a problem that is merely an aestetic issue. I'm more interested in finding out if the 07s have the same setup or if the changes to the head unit resulted in a separate circuit board for the climate control. Link to comment Share on other sites More sharing options...
