jholder Posted July 14, 2006 Share Posted July 14, 2006 Did I miss the LEgacy specific spring install DIY guide? Tried searching didn't find it --james Link to comment Share on other sites More sharing options...
lookslikeanevo Posted July 14, 2006 Share Posted July 14, 2006 cus its the same as any other spring install Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
Scooter Posted July 14, 2006 Share Posted July 14, 2006 Perhaps your search methods leave something to me desired...? haha These are the guides I used, although Brother L...O above has a point, unhelpful as it may be: we're talking 4 bolts each side on the rears and 5 bolts each side on the fronts. Only tricky part is marking the camber bolt on the front: the markings are on the head of the upper bolt for the lower strut mount. Also, you won't be able to disassemble the front strut assy without an impact wrench, unless you have a very specialized pass-thru socket set. http://www.legacygt.com/forums/showthread.php?t=5757 http://www.legacygt.com/forums/showthread.php?t=14443&highlight=springs http://legacygt.com/forums/showthread.php?t=19989\ http://www.legacygt.com/forums/showthread.php?t=15558&highlight=springs Feel free to PM me with any questions. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
