kkushner4474 Posted July 12, 2006 Share Posted July 12, 2006 I have searched around about sticky clutches and people have problems of the clutch sticking and revving at high rpms and a good stink I have had a stink when coming out of first gear to quickly But my main problem is the clutch sticks to the floor to the point where I have to lift it back up myself My clutch has never stuck to have the rpms stick anywhere The whole time I press down on the clutch it goes in like butter and it is not till the last inch or two that the clutch actually engages Some days it’s completely fine and others it’s the clutch from hell I’ve read about people saying its CDV or the master cylinder I have bleed the clutch line and got some air to come out but the clutch was good for a day and after that its back to being hell So what is a for sure cure with out getting a new clutch cuz that is a pain Link to comment Share on other sites More sharing options...
Flanders Posted July 12, 2006 Share Posted July 12, 2006 ScoobyMods - Clutch Sticking TSB Link to comment Share on other sites More sharing options...
whitetiger Posted July 12, 2006 Share Posted July 12, 2006 here is the solution- SPEC Stage Clutch Kits for the 2005+ Subaru Legacy GT, JSC Speed I have the stage 3+ clutch. never had it slip or stink ever. Link to comment Share on other sites More sharing options...
Flanders Posted July 12, 2006 Share Posted July 12, 2006 He has a 99. Link to comment Share on other sites More sharing options...
kkushner4474 Posted July 12, 2006 Author Share Posted July 12, 2006 He has a 99. thankyou Link to comment Share on other sites More sharing options...
SLegacy99 Posted July 12, 2006 Share Posted July 12, 2006 I had the same problem in my '99 after I replaced the clutch. You need your master cylinder replaced. $200. Link to comment Share on other sites More sharing options...
kkushner4474 Posted July 22, 2006 Author Share Posted July 22, 2006 The thing is i got a new clutch when i had to put in a new headgasket in january/Febuary I had the flywheel cut didnt get a new one of that. Link to comment Share on other sites More sharing options...
Flanders Posted July 23, 2006 Share Posted July 23, 2006 So you still have the sticky clutch pedal? Link to comment Share on other sites More sharing options...
SLegacy99 Posted July 24, 2006 Share Posted July 24, 2006 I had the same problem in my '99 after I replaced the clutch. You need your master cylinder replaced. $200. Link to comment Share on other sites More sharing options...
