SWP-LegacyGT Posted July 6, 2006 Share Posted July 6, 2006 People are buzzing about the SI drive in the new '07's+. Now, from what I've heard, (this is just a rumor...nothing more) the dial that switches between the 3 different mods actually are 3 different chips on the ECU. Put 1+2 together and you now release what the next-gen Cobb AP's and the ECUTek kits are going to be like. First, you'll have the base flash which will be your base map and then using your SI dial, you'll have point and click option to have a 1 of 3 real-time maps active at your bidding. That's right. High Boost-Economy-Track/Valet whatever... pick the combo you want and that's how it's going to be directed. Reason I'm hearing that Cobb has been so slow to release the 1.16 map is because of their R+D on the new SI driveline. So, that being said, we'll probably be hearing something about this in the next 3-9 months or so. Link to comment Share on other sites More sharing options...
bmorrisj Posted July 6, 2006 Share Posted July 6, 2006 why put valet on the same knob you have high boost on? Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted July 6, 2006 Author Share Posted July 6, 2006 Why not? Depends on the person flashing their car I would imagine. Link to comment Share on other sites More sharing options...
Deer Killer Posted July 6, 2006 Share Posted July 6, 2006 the dial that switches between the 3 different mods actually are 3 different chips on the ECU.Well that sounds horrendously wasteful. I'm sure it's just 3 different sets of maps. There's plenty of rom space available. The people that have source code can do nearly anything in software. They just don't.. Lack of budget or lack of imagination.. *shrug* Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted July 6, 2006 Author Share Posted July 6, 2006 Possibly. And also I'm thinking the 3 chips part seems a bit off, but there might be better program management to allow 3 real-time maps at once. Link to comment Share on other sites More sharing options...
red beast Posted July 6, 2006 Share Posted July 6, 2006 250 hp 300 hp 350 hp Link to comment Share on other sites More sharing options...
Jon in CT Posted July 6, 2006 Share Posted July 6, 2006 Well that sounds horrendously wasteful. I'm sure it's just 3 different sets of maps. There's plenty of rom space available.Exactly. Three different sets of base maps for throttle control, boost control, spark advance, etc. Link to comment Share on other sites More sharing options...
dv8ingvector Posted July 6, 2006 Share Posted July 6, 2006 I am sure someone could figure out how to install a switch to disable the knob to make the valet, econo, and an alky injection map all work only when and were you want. Link to comment Share on other sites More sharing options...
Legacy BoB Posted July 6, 2006 Share Posted July 6, 2006 Being able to switch maps can make it more practicle to have maps that are more setup for racing, and even make the economy mode less annoying as long as it enables you to switch it on the fly. Turn on economy map when you are just cruising at a steady speed on the highway for a long time switch it back to a more normal mode when you have to pass traffic or just get bored of cruise control. Or have a racing map for the track and just hit the knob to go back to a more conservitive map for the driving around the streets. If they can get the knob to work with the custom maps I think it will be something most people will end up using more than they thought they would. Link to comment Share on other sites More sharing options...
andrew.anderson Posted July 6, 2006 Share Posted July 6, 2006 I know nothing about SI Drive other then what I have read from Subaru but if ECUTek and COBB are able to make it so you an use the SI switch to switch MAPs that would be great for SOA 07 Sales. Link to comment Share on other sites More sharing options...
