t0ad Posted July 5, 2006 Share Posted July 5, 2006 So over the weekend I poked around on my LGT and noticed that when totally cold, my front differential dipstick reads just a hair over the L mark. I guess my first question is, is that okay for a totally cold reading? It's kinda tough to get in there and check when things are warm. Second question, since I bought the car used, I have no clue what's in it, fluid-wise. I can only assume it's still the original fluid from the factory, as the car only had 28k on it when I bought it. Now, would it be alright to go grab some OEM stuff from the dealership and top it off? What about other brands of 85W gear oil? Or should I just drain both diffs at 30k and replace with Redline Link to comment Share on other sites More sharing options...
Xenonk Posted July 5, 2006 Share Posted July 5, 2006 1) yes, but you can add another 1/2 qt in. 2) you're ok with mixing.. but at 28k, it's time to change it out anyways.. a lot us just buy 75w90 NS Redline tranny/diff oil.. (edit: I just noticed that you are from WV.. I will be up that way at Summit Point this whole weekend and Friday running the GT on the main circuit with a few other Subaru owners, come up and watch if you have the time). Keefe Link to comment Share on other sites More sharing options...
t0ad Posted July 5, 2006 Author Share Posted July 5, 2006 Cool. I remember reading a big thread about tranny/diff oils .. ended up rather confusing. 75w90 NS in the rear diff since it's limited slip, so should the front diff (auto) use regular 75w90? What about the tranny? I had no idea Summit Point existed until I read about it on here. Sucky thing is it's way over on the panhandle, which is like 300 miles from me Link to comment Share on other sites More sharing options...
mbacis Posted July 19, 2006 Share Posted July 19, 2006 From the service manual (differential oil replacement section): NOTE: Each oil manufacturer has its base oil and additives. Thus, do not mix two or more brands. Link to comment Share on other sites More sharing options...
