subieleg Posted June 28, 2006 Share Posted June 28, 2006 The other day i spent about an hour taking stuff apart so i could install my amp and sub... But what i firured/was told was easy to install wasnt easy. i have all the ground wires, battery fuse and cable so on to install no wiring harness or anything because i was told i might not need it. anyways ppl told me it was easy there should be a audio in audio out hook ups on the stereo well there wasnt. so anyone know what i need to install a Kenwood 800 watt, or a kenwood 1000 watt amp and a 12 inch RF sub to my stock stereo? And a question about the sub bass. what will i need to adjust the bass manually so i dont just have the amp volume controlls? Link to comment Share on other sites More sharing options...
jazzymt Posted June 28, 2006 Share Posted June 28, 2006 It sounds like what you want/need is a line out converter. One that has volume control would be good (that's what you're asking for right?). And one that corrects the factory eq would be best (like a JL Cleansweep or RF 3Sixty). [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
subieleg Posted June 29, 2006 Author Share Posted June 29, 2006 awesome thanks for the help. I have been hearing alot about the cleansweep must be good Link to comment Share on other sites More sharing options...
gfxdave99 Posted June 29, 2006 Share Posted June 29, 2006 awesome thanks for the help. I have been hearing alot about the cleansweep must be good If you want to run your stock system but just have more bass, a cleansweep would be a waste of cash for just that. The Cleansweep is great, dont get me wrong, but overkill for just adding a sub. Now if you want to keep your stock look, have great quaility sound source and replace all of your speakers and amplify all of them (adding a 4x amp in addition to the sub and re-wiring all the speakers) its worth the time and money over just a regular line output converter. While i dont have a cleansweep, I have had a entire higher end system in my legacy GT running off of the stock HU with line output converters and now have a single DIN headunit in my cubby and the difference between the stock head unit and a good quality source is night and day.. so if you dont like the idea of a stereo in your cubby the cleansweep is worth the investment, but if you think the stock system sounds okay to you and you just need more boom, then get a line output converter, splice into the rear speaker harness so you can run RCA outs to your sub amp If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
subieleg Posted June 30, 2006 Author Share Posted June 30, 2006 Thanks for the help. i was acutally thinking today im just going to have a new head unit installed might as well go all the way. Link to comment Share on other sites More sharing options...
