trubspecb Posted June 21, 2006 Share Posted June 21, 2006 i have a new 3.0R Spec B Legacy (Legend) in the UK with the above symptoms have any of you guys had this problem and do you know the fix? i dread the dealer ripping my car apart to try and find the solution! await your help and thanks in anticipation Link to comment Share on other sites More sharing options...
harrigan Posted July 9, 2006 Share Posted July 9, 2006 I don't have exactly that problem, but perhaps something related -- I've noticed a fair bit of static on AM stations that sounded fine in my previous car (have 06 LGT sedan), and the static is often alleviated when I press the brake pedal. Something to do with grounding perhaps? I had the car in for its first service and pointed out this issue... was told that because I had the back window tinted (by the damned dealer, who didn't warn me about this) they couldn't troubleshoot the problem without peeling off the tiny. :[ Link to comment Share on other sites More sharing options...
Jon in CT Posted July 9, 2006 Share Posted July 9, 2006 If you have a wagon, there could be a grounding/earthing problem. Subaru has issued a service bulletin about ignition noise during weak AM station reception: http://www.thel7.com/TSB/15-115-05.pdf Link to comment Share on other sites More sharing options...
harrigan Posted July 9, 2006 Share Posted July 9, 2006 I have the sedan, but thanks for the tip. Will mention to my dealer. Link to comment Share on other sites More sharing options...
