spacejunkiehsv Posted June 15, 2006 Share Posted June 15, 2006 I was looking at this thread and doing a little exhaust system learning. It brings up a question for me. http://www.legacygt.com/forums/showthread.php?t=8084 I think there are 3 cats in a stock 2005 Legacy GT exhaust system. (1) In the uppipe (2) In the downpipe (3) Far back in the stock cat back If that is right, does the Cobb catless downpipe take car of cats #2 and #3 at the same time? I'm thinking that just replacing the stock uppipe and downpipe with the Cobb catless downpipe and uppipe would still leave the 3rd cat in the exhaust system? Link to comment Share on other sites More sharing options...
D0WNxSH1FT Posted June 15, 2006 Share Posted June 15, 2006 The Cobb Downpipe has two options: Downpipe w/o High Flow Cat = $425 Downpipe w/ High Flow Cat = $575 To answer your question, if you get the DP it will replace both the DP-cat and Midpipe-Cat. here is info from cobbtuning.com "Starting with the basics, our downpipe replaces the two factory catalytic converters located directly after the turbocharger. These parts are commonly called the downpipe and 3rd cat or mid-pipe cat." Link to comment Share on other sites More sharing options...
sutter2k Posted June 15, 2006 Share Posted June 15, 2006 http://www.subydude.com/images/prod/products/Engine/700/700/wrx-intake-exhaust-diagram.gif You would be without cats. 1-in uppipe 1-downpipe 1-mid pipe cobb down pipe = a shorty downpipe and mid pipe welded together as one piece Link to comment Share on other sites More sharing options...
D0WNxSH1FT Posted June 15, 2006 Share Posted June 15, 2006 That diaghram is amazing. i have used it time and time again over the past year. Link to comment Share on other sites More sharing options...
spacejunkiehsv Posted June 15, 2006 Author Share Posted June 15, 2006 You would be without cats. 1-in uppipe 1-downpipe 1-mid pipe cobb down pipe = a shorty downpipe and mid pipe welded together as one piece Thanks. That's what I wanted to know. Link to comment Share on other sites More sharing options...
