achtung Posted September 11, 2004 Share Posted September 11, 2004 Driving a MY2000 RSK Turbo. This problem occurs at times. When I full thorttle from stationery and when I switch from 1st to 2nd gear, the engine stall. Diagnostic tool shows no error codes. Any feedback from anyone? Link to comment Share on other sites More sharing options...
apexjapan2 Posted October 1, 2004 Share Posted October 1, 2004 MAF would be my first guess. Join the legacyb4 group on yahoo to get first hand knowledge from TT owners worldwide. HTH :) Link to comment Share on other sites More sharing options...
achtung Posted October 2, 2004 Author Share Posted October 2, 2004 MAF sensor is new and I have joined all B4 forums on Yahoo and elsewhere. [quote name='apexjapan2']MAF would be my first guess. Join the legacyb4 group on yahoo to get first hand knowledge from TT owners worldwide. HTH :)[/quote] Link to comment Share on other sites More sharing options...
apexjapan2 Posted October 2, 2004 Share Posted October 2, 2004 Haven't seen you post on legacyb4 AFAIK. MAF and 02 sensors don't show on the error codes. Do you have any leaks? Air leaks, funky BOV could also do things like that by messing up the AFRs. What mods do you have? Link to comment Share on other sites More sharing options...
achtung Posted October 2, 2004 Author Share Posted October 2, 2004 I have got no BOV installed. Only Blitz Open Pod Filter, Oil Cooler and thats all. [quote name='apexjapan2']Haven't seen you post on legacyb4 AFAIK. MAF and 02 sensors don't show on the error codes. Do you have any leaks? Air leaks, funky BOV could also do things like that by messing up the AFRs. What mods do you have?[/quote] Link to comment Share on other sites More sharing options...
apexjapan2 Posted October 2, 2004 Share Posted October 2, 2004 IMHO, get rid of the filter, it is a MAF killer, and even if the MAF works, they often cause the MAF of that era to read wrong. Pod filters and pipes from another bigname Japanese out fit caused the same problems on a couple of cars we had to fix. Just chucking them away fixed it... That era MAF hates those intakes, so IMHO a good panel is the way to go (my car is well over 310ps and runs a std airbox w/replacement panel filter). If your std BOV is sticking or faulty, it can mess up the AFR on shifts which I guess in extreme cases could stall the motor. Have you had the car looked at? Link to comment Share on other sites More sharing options...
skywalker Posted October 16, 2004 Share Posted October 16, 2004 I agree with apexjapan2, my guess is that MAF sensor is getting some wierd readings from the pad filter. Usually those filters are designed to make the car run leaner, though sometimes as the car gets older that can actually be too lean and would make sense why your car is stall in between shifts. So go get a panle filter and install the stock box back into place. If anything that improve the performance of the car with cooler intake temps also. Cheers, Bill Knose Lead Tuner I-Speed USA [url]www.i-speed.us[/url] Link to comment Share on other sites More sharing options...
