The Don Posted June 2, 2006 Share Posted June 2, 2006 on the site it has 60MM WARNING GAUGES 60MM MECHANICAL GAUGES 60MM ELECTRONIC GAUGES 52MM ELECTRONIC GAUGES I want a regular boost gauge which one do it Pick?? Link to comment Share on other sites More sharing options...
NutBucket Posted June 2, 2006 Share Posted June 2, 2006 Well that depends on what you mean by "regular". I'll assume regular means mechanical so you're getting a 60mm mechanical gauge. Link to comment Share on other sites More sharing options...
The Don Posted June 2, 2006 Author Share Posted June 2, 2006 whats the diff? Link to comment Share on other sites More sharing options...
doogdog Posted June 2, 2006 Share Posted June 2, 2006 whats the diff? Mechanical gauges require you to run a line into your car (boost signal line) and it plugs in the back of the gauge. An electronic gauge has a seperate sending unit that's usually monted under the hood. The sending unit converts the signal and sends it electronically through wires. It's a matter of personal preference, mechanical are said to respond a little quicker. You can't go wrong either way IMO. Rick Link to comment Share on other sites More sharing options...
The Don Posted June 2, 2006 Author Share Posted June 2, 2006 Would i also need a pod or a mount... im havin subie hook it up?? Link to comment Share on other sites More sharing options...
doogdog Posted June 3, 2006 Share Posted June 3, 2006 Would i also need a pod or a mount... im havin subie hook it up?? You will need a gauge cup or some sort of mount for your gauge. I'd reccomend the Autometer gauge cups, relatively inexpensive and they look great. Rick Link to comment Share on other sites More sharing options...
