Alain969 Posted June 1, 2006 Share Posted June 1, 2006 Did somebody test these wheels on Legacy GT? I want to know if the clearance of the galiper are ok.Just the wheel not the tire. This Wheel is 48mm and the stock wheel on Gt is 54mm! This wheel is now on 06 Outback XT Limited OEM OBXT and i will fit on Legacy GT 2005. Link to comment Share on other sites More sharing options...
cbroo Posted June 1, 2006 Share Posted June 1, 2006 They fit ok on a 01', so probably on a 05' is ok, I think, most likely Link to comment Share on other sites More sharing options...
KA81 Posted June 1, 2006 Share Posted June 1, 2006 they will fit the question is which tires will make it work Link to comment Share on other sites More sharing options...
Alain969 Posted June 1, 2006 Author Share Posted June 1, 2006 The photograph of the wheel are the wheel of origin of one 06 Outback XT Limited OEM OBXT. The tires are my tires of origin 215/45/17. You try this? because the brake before Legacy GT are larger than Outback OBXT according to Subaru Dealer. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted June 1, 2006 Share Posted June 1, 2006 Someone told me that the offset is different, which means that the wheels stick out a bit further in the fenders? I think it's because of the Outback's fender flares. Link to comment Share on other sites More sharing options...
Alain969 Posted June 1, 2006 Author Share Posted June 1, 2006 Another opinion PLEASE someone try this? The 2 wheel is 17/7 Link to comment Share on other sites More sharing options...
EL PAALO Posted June 1, 2006 Share Posted June 1, 2006 caliper clearance is the only question. 7 +48 will certainly fit no prob as far as fender clearance goes. Link to comment Share on other sites More sharing options...
praedet Posted June 1, 2006 Share Posted June 1, 2006 I am running a 48 mm offset 17" rim on my LGT, they will work... Link to comment Share on other sites More sharing options...
EL PAALO Posted June 1, 2006 Share Posted June 1, 2006 spoke design is a main factor for brake clearance. your fn01rc have very good caliper clearance. Link to comment Share on other sites More sharing options...
praedet Posted June 1, 2006 Share Posted June 1, 2006 It won't be a problem... Link to comment Share on other sites More sharing options...
