SLegacy99 Posted May 28, 2006 Share Posted May 28, 2006 I worked 14 hours today and its late and I am tired so I need some help figuring this one out. About every 15 seconds I can hear a loud pop come from beneath the hood. It is similar to that of the popping noises when the car has just been turned off and cooling down. In comparrison to the typical pop noise it is magnified Id say 3 times the normal volume. It continues after the car has been turned off. It never did this before. Only change I have made was adding half a quart of 10W-30 a few days ago. Link to comment Share on other sites More sharing options...
nhesketh Posted May 28, 2006 Share Posted May 28, 2006 Well, that is weird. Have you "popped" the hood to narrow down where the noise is coming from? It may be obvious if you can trace it to its source. So it sounds like a cooling contraction tick, but louder? neil Link to comment Share on other sites More sharing options...
SLegacy99 Posted May 28, 2006 Author Share Posted May 28, 2006 I did pop, but again Im dead tired so I guaged that it is coming the front, but I didnt really stick my head down there to listen. And yes, a louder tick. I originally heard it sitting at a stoplight with no windows open. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 28, 2006 Share Posted May 28, 2006 so it does it when it's running....and when it's off? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Rely18 Posted May 28, 2006 Share Posted May 28, 2006 metal parts expanding/contracting? Link to comment Share on other sites More sharing options...
kenzo Posted May 28, 2006 Share Posted May 28, 2006 Is there also a "snap" and a "crackle"? Link to comment Share on other sites More sharing options...
cbroo Posted May 28, 2006 Share Posted May 28, 2006 I worked 14 hours today and its late and I am tired so I need some help figuring this one out. About every 15 seconds I can hear a loud pop come from beneath the hood. It is similar to that of the popping noises when the car has just been turned off and cooling down. In comparrison to the typical pop noise it is magnified Id say 3 times the normal volume. It continues after the car has been turned off. It never did this before. Only change I have made was adding half a quart of 10W-30 a few days ago. You have aftermarket exhaust? I have the same condition it's only when I run the car for a little while. I uset to hear it all the time in the winter when I start up the car. Basically it's really nothing to worry about. The noise is caused by air either lack of in or out flow its weird I had subaru look at this a year ago and they had said this do to my exhaust, I dont know if I believe them but my car still runs fine. Mine hasnt done it for a few a week or so but I did hear hit at the red rocks meet. Link to comment Share on other sites More sharing options...
cbroo Posted May 28, 2006 Share Posted May 28, 2006 but now that I think mine isnt like parts coolong more of a weird backfire sound but mufffled and low but I would check the intake area but I cant imagine what it would be. almost like a lose part Link to comment Share on other sites More sharing options...
GTsleeper Posted May 28, 2006 Share Posted May 28, 2006 its in the exhaust. it happens running & not. its getting warmer out maybe a/c running the car is alot hotter underneath. just look make sure heat shields, stuff like that are good, even bang on the exhaust- something loose inside the exhaust..... dont think i have to say but will-- when cold/cool of course. but like said before most likly just expand/contract of metal.. & also i see ur in snow areas so maybe patches of salt/no sure whats used there are being burned off Link to comment Share on other sites More sharing options...
SLegacy99 Posted June 20, 2006 Author Share Posted June 20, 2006 Still havent figured this one out. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted June 20, 2006 Share Posted June 20, 2006 Once you pop, you can't stop. Link to comment Share on other sites More sharing options...
SLegacy99 Posted June 20, 2006 Author Share Posted June 20, 2006 Once you pop, you can't stop. Touche. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted June 20, 2006 Share Posted June 20, 2006 Bump Link to comment Share on other sites More sharing options...
Jedi Pimp Posted June 20, 2006 Share Posted June 20, 2006 Its the coolant expanding from the head gasket leak..... *ducks* Link to comment Share on other sites More sharing options...
SLegacy99 Posted June 20, 2006 Author Share Posted June 20, 2006 Its the coolant expanding from the head gasket leak..... *ducks* Very funny. My exhaust would be white. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted June 21, 2006 Share Posted June 21, 2006 Bump Link to comment Share on other sites More sharing options...
