Dodger Posted May 19, 2006 Share Posted May 19, 2006 So, I've read the spring install walk-through, but I decided to pay and have the install / alignment professionally done. For sh*ts and giggles, I called a local dealer and they quoted $580 for the install and alignment. Now I'm pretty sure there are other places that will do a good job and not charge soo much. I've looked around and saw some good things said about Roger Kraus Racing and Auto Innovations. I'm in the Sacramento area and would rather do this around here. But I'd be willing to goto the Bay area for a good installer that's familiar with the Legacy. Suggestions anyone? Link to comment Share on other sites More sharing options...
CreoSTi Posted May 20, 2006 Share Posted May 20, 2006 If you're willing to make the trek to Novato, I highly recommend LIC Motorsports. Adam/Kevin/Noah are all great to work with, and they deal pretty much specifically with Subarus. They've installed springs on a Legacy before, and they installed coilovers on my spec.B. http://www.licmotorsports.com/main.htm -Mike- Link to comment Share on other sites More sharing options...
pleiad7 Posted May 20, 2006 Share Posted May 20, 2006 +1 for LIC... they've done countless spring installs, including mine. They don't do alignments, but they might be able to refer you to a reputable alignment place. Link to comment Share on other sites More sharing options...
aldouse Posted May 20, 2006 Share Posted May 20, 2006 auto innovations here in milpitas would charge you roughly about $250 for installs w/ alignment. ask for orlando. they did wonders on my car. -- yay for the sig! -- my garage! Link to comment Share on other sites More sharing options...
Dodger Posted May 21, 2006 Author Share Posted May 21, 2006 Thanks for the replies. It doesn't look like LIC is open on weekends, which makes its harder for me to get there. Auto Innovations seems promising since they also do alignments. Any ideas how long this install takes? Link to comment Share on other sites More sharing options...
aldouse Posted May 21, 2006 Share Posted May 21, 2006 2-3 hours @ auto innov w/ alignment. -- yay for the sig! -- my garage! Link to comment Share on other sites More sharing options...
JuxtaGT Posted June 2, 2006 Share Posted June 2, 2006 Not sure where you are located, but Custom Alignment in Mountain View is IMO the best place to get an alignment done. Link to comment Share on other sites More sharing options...
Dodger Posted June 3, 2006 Author Share Posted June 3, 2006 I'm in the Sacramento area. Thanks for the Custom Alignment referral; appearently only the bay area has good suspension people. General question here: I always thought alignment is a one-time adjustment. Meaning that once the alignment is done, its good for a period of time. I wouldn't have to go back to adjust the alignment the following day(s), right? I've never had to before, and I'm assuming its also the case with the legacy. Still waiting on the pinks. Hopefully I can get them on in the next 2 weeks. Link to comment Share on other sites More sharing options...
CreoSTi Posted June 3, 2006 Share Posted June 3, 2006 I always thought alignment is a one-time adjustment. Meaning that once the alignment is done, its good for a period of time. I wouldn't have to go back to adjust the alignment the following day(s), right? That is correct. However, sometimes springs can settle (lower) a bit post-installation, which is why I usually wait a week or two before getting an alignment. -Mike- Link to comment Share on other sites More sharing options...
Dodger Posted June 3, 2006 Author Share Posted June 3, 2006 Creo, thanks for the tip. Makes sense; I should of thought about it more. Aside: When you receive the springs, does it come with the rubber/foam wrapping to reduce the clunking sound? Or does the installer put that on for you? Link to comment Share on other sites More sharing options...
CreoSTi Posted June 3, 2006 Share Posted June 3, 2006 Aside: When you receive the springs, does it come with the rubber/foam wrapping to reduce the clunking sound? Or does the installer put that on for you? Some companies do, and some don't. The Espelir ASDs on my old STi didn't, while the Prodrive-manufactured ones did (on the front at least). I had the Espelirs first and they "clunked" all the time. I removed the coil insulators from the stock springs, and just put them roughly in the same position on the Espelirs and the Prodrive rears. The noise went away, but the ASDs weren't very good, so I ended up switching to the Prodrives. -Mike- Link to comment Share on other sites More sharing options...
Mann Engineering Posted June 8, 2006 Share Posted June 8, 2006 We use all three shops for installation and alignment and highly recommend anyone of them. Custom Alignment Auto Innovations - Ask for Steve. LIC Motorsports The spring quieter is dependant on the spring manufacturer. We know that many companies do include it like Swift and STi. The one time adjustment will also depend on each spring manufacturer. Some will take time to settle and some will not need this time. Regards, Gary Link to comment Share on other sites More sharing options...
