erito Posted May 15, 2006 Share Posted May 15, 2006 Tried to open the car, but no reaction. Opened with the key 'old-school' and tried to start the car, but no reaction. I'm sure all doors were closed when i left it yesterday, how could the battery die so quick? I'll try to recharge the battery today and see if everything's okay. Link to comment Share on other sites More sharing options...
panamajack Posted May 15, 2006 Share Posted May 15, 2006 probably left your parking lights on. Its the switch on top of the steering wheel. Link to comment Share on other sites More sharing options...
erito Posted May 15, 2006 Author Share Posted May 15, 2006 Maby i pushed that button without knowing it... anyway the battery should handle 24hours parkinglight? I have a 12v 6A charger i will use after work today and see what happens. Link to comment Share on other sites More sharing options...
pillboy Posted May 15, 2006 Share Posted May 15, 2006 Maby i pushed that button without knowing it You wouldn't be the first person to do so accidentally. I doubt the battery could run parking lights for 24 hours. It is still ugly. Link to comment Share on other sites More sharing options...
gargleblaster Posted May 15, 2006 Share Posted May 15, 2006 Its the switch on top of the steering wheel.What some of us adoringly call "The Battery Killer". Founder - The Harry F. Johnson Memorial Fund Link to comment Share on other sites More sharing options...
Terrain.org Posted May 16, 2006 Share Posted May 16, 2006 I saw on Edmunds.com that someone did the same thing, but with a front map light. Believe it or not, that alone drained the battery. Link to comment Share on other sites More sharing options...
laramieskibum Posted May 16, 2006 Share Posted May 16, 2006 map lights killed mine in less than 48 hours, but I've left them on overnight and it has started fine. If they just would have wired the map lights to the door switch....My Jeep TJ has better lighting for the front seat. Might consider doing the mod on this site to do that. Link to comment Share on other sites More sharing options...
erito Posted May 16, 2006 Author Share Posted May 16, 2006 now i know what it was. The small roof-light in the back center (just close to the rear hatch). I must have bumped my head in the switch while taking out some stuff. It totally drained the battery, but a 2,5 hour re-charge restored everything. The cd-player ejects the disc just before the battery dies, maby a useful feature Link to comment Share on other sites More sharing options...
mickeyd2005 Posted May 16, 2006 Share Posted May 16, 2006 I think the OEM batteries are the minimum necessary to get the car started in cold weather. They don't have much reserve capacity. I've left the parking light on overnight and have not had a problem in my '98 Outback with relatively new Costco battery. I've also left all the dome lights on my Odyssey on overnight. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 16, 2006 Share Posted May 16, 2006 Stock battery is pretty crappy in the reserve department.... I always have the radio on when i'm working on the car and I also have a digital voltmeter that gives an alarm at 11.5 volts.....which should be plenty to start a car. well, our battery can't even crank at 11.8 volts My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
erito Posted May 16, 2006 Author Share Posted May 16, 2006 My crappy OEM battery has PANASONIC printed all over. Same as the US built OB? But as i think about it, the light might have been on for 48 hours... still a very small lightbulb in that roof-light... Link to comment Share on other sites More sharing options...
Meltdown07 Posted May 16, 2006 Share Posted May 16, 2006 now i know what it was. The small roof-light in the back center (just close to the rear hatch). I must have bumped my head in the switch while taking out some stuff. It totally drained the battery, but a 2,5 hour re-charge restored everything. The cd-player ejects the disc just before the battery dies, maby a useful feature I did that too once, but my car survived the night to start the next morning. guess I am lucky. Go Cardinals! Link to comment Share on other sites More sharing options...
whitetiger Posted May 16, 2006 Share Posted May 16, 2006 Leave the battery drain switch alone. Link to comment Share on other sites More sharing options...
erito Posted May 16, 2006 Author Share Posted May 16, 2006 i will try to leave it, but it's sooo tempting... Link to comment Share on other sites More sharing options...
