MaStaMooN Posted May 9, 2006 Share Posted May 9, 2006 Here are a few pictures of my install. What it is, is the suction cup mount, turned upside down and pushed into the cubby. It fits tightly and never moves unless I want it to. This mounting solution is great for me because it still allows the rotation/tilt/adjustments of the suction cup mount to work. This is good since my wife likes to surf the channels and allows her to rotate the face towards her to read the LCD. I can also just move the entire mount to face either me or her. This is installed along with the Jazzy Aux-In board... please excuse the white wire behind the unit.. That is a Y adapter so I can plug in my Dell Axim x50V or iPod without having to unplug the sirius unit. Its also hardwired for power to the cig lighter. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
mevanvt Posted May 9, 2006 Share Posted May 9, 2006 I'm actually about to do this with my sportster. How did you run the wires? Did you just drill a hole in the back of the cubby and run them down? Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 9, 2006 Author Share Posted May 9, 2006 yeah, I had a boost gauge in their previously.. so I just used that hole that I dremeled out for the wires. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
tjm0852 Posted May 12, 2006 Share Posted May 12, 2006 I removed the cubby space entirely and mounted my Starmate in a panel I replaced the cubby with. The unit can easily be removed for home use. http://www.hostdub.com/albums/tjm0852/SiriusInstall.sized.jpg http://www.hostdub.com/albums/tjm0852/SiriusInstall3.sized.jpg http://www.hostdub.com/albums/tjm0852/SiriusInstall4.sized.jpg I have another mounting plate I need to wrap and install. This first one was a test. The new one has the unit centered better. Link to comment Share on other sites More sharing options...
Kolbenson Posted March 22, 2007 Share Posted March 22, 2007 I like this last one (starmate with cubby removed ) I would like to do this with my sportster. Link to comment Share on other sites More sharing options...
zmarko Posted March 22, 2007 Share Posted March 22, 2007 I like this last one (starmate with cubby removed ) I would like to do this with my sportster. I'd respectfully disagree. Looks rather non-professional to me. Plus with the non-dual-zone climate control, you can easily get an aftermarket unit with Sirius/XM built in and keep the cubby at the same time. Link to comment Share on other sites More sharing options...
TRAC3 Posted March 24, 2007 Share Posted March 24, 2007 spend enough time with a dremel, and you can have your sirius anywhere you want... http://img.photobucket.com/albums/v706/HotRod03/IMG_4299.jpg http://img.photobucket.com/albums/v706/HotRod03/IMG_4297.jpg and keep your cig lighter http://img.photobucket.com/albums/v706/HotRod03/IMG_4294.jpg and have the cubby hole for other mods http://img.photobucket.com/albums/v706/HotRod03/IMG_4259.jpg Link to comment Share on other sites More sharing options...
TPLGT Posted March 24, 2007 Share Posted March 24, 2007 Damn some of you guys will cram your unit into anywhere you can find! You need to see someone about this. Rehab is for quitters. Link to comment Share on other sites More sharing options...
nKoan Posted March 24, 2007 Share Posted March 24, 2007 Damn some of you guys will cram your unit into anywhere you can find! You need to see someone about this. I put my Sirius One on top of a defi control unit in my cubby. It *almost* closes right now, and with a little more dremeling, it should be good to go. Anyway, I'll try to get some pics when I get back home. Link to comment Share on other sites More sharing options...
jingjing Posted March 24, 2007 Share Posted March 24, 2007 heres mine : http://i3.photobucket.com/albums/y86/jingjingecr3/Picture337.jpg held by a bracket and double sticky tape. works great, easy to see and adjust. Link to comment Share on other sites More sharing options...
