niskyne Posted May 8, 2006 Share Posted May 8, 2006 First off...sorry about the 2 threads in a row. I just found out about this problem. after I posted the other one. I just got my new megan racing boost guage in the mail today from ebay. I took it out to look at it today a few minutes ago, and I'm pretty sure it's missing some hardware. There is nothing that can fit onto the nylon pressure hose to make an air tight seal. On the instructions, there is a "compression sleeve" (i circled them) pictured that fits in between the adaptor on the guage and the vacuum nipple to make an airtight seal when the compression nut is tight. So I'm pretty sure I am missing these "compression sleeves" that fit onto the nylon pressure hose. Can I get these at an autoparts store? Or do I need to contact the person I bought the guage from to get these items (the person is really slow at contacting)? Or does anyone have any extras laying around that I can buy? Also, what do the compression sleeves do? Thanks everyone. Link to comment Share on other sites More sharing options...
niskyne Posted May 8, 2006 Author Share Posted May 8, 2006 here's the pics. shows part of the instructions, and the hardware that came with it. Link to comment Share on other sites More sharing options...
scans007 Posted May 8, 2006 Share Posted May 8, 2006 Contact the ebay seller and get the compressions sleves from them....if it should be in the box, they are responsible for it..... Link to comment Share on other sites More sharing options...
CasopoliS Posted May 8, 2006 Share Posted May 8, 2006 Just go to an auto parts store and pick up some vac hose and small hose clamps. Run vac hose all the way from your boost source to the gauge... clamping on each end. Use the barbed fitting at the boost gauge. Its about $.50 / foot for the hose.... take the fittings in so they get you the right size. Link to comment Share on other sites More sharing options...
niskyne Posted May 8, 2006 Author Share Posted May 8, 2006 So they don't sell universal compression sleeves at any autoparts store? I would rather run the vauum hose to the fender grommet, and then from there reduce it to the nylon vacuum line supplied with the guage. Link to comment Share on other sites More sharing options...
CasopoliS Posted May 8, 2006 Share Posted May 8, 2006 My megan racing boost gauge came with flexible pvc vac hose.... though I will get some rubber stuff from AutoZone. I have a little tool that stabs stuff like this through firewall grommets. Link to comment Share on other sites More sharing options...
