eVoMotion Posted August 19, 2005 Share Posted August 19, 2005 What is the alarm off/valet mode? Does that turn the alarm off, keep the car from locking itself with keys in it (loved that the first time it happened) and restrict the RPMs to less than 3000? Link to comment Share on other sites More sharing options...
Lagacy GT Posted June 30, 2006 Share Posted June 30, 2006 So if you have a LGT, it comes with alarm? Because I've never heard mine go off. I thought I only had keyless entry. Hmm, maybe it's been in valet mode since I bought it? Link to comment Share on other sites More sharing options...
Fallschirmjaeger Posted June 30, 2006 Share Posted June 30, 2006 Best to check, I KNOW mine was delivered in valet mode. Link to comment Share on other sites More sharing options...
iguanamafia Posted July 2, 2006 Share Posted July 2, 2006 [quote name='Zeus']Anyone know thw answer to this one? Matter of fact, where is the "shock sensor" located?[/quote] It used to be under the center console in years past. On the brain there was a reostat/ potentiometer that you could adjust the sensitivity with on the brain. I am guessing that all still exists. Link to comment Share on other sites More sharing options...
ama0787 Posted April 26, 2007 Share Posted April 26, 2007 On navigation equipped vehicles you can change the defrost timer (front,rear) options through it. Also light times alarm sensitivity and some keyless entry options. Link to comment Share on other sites More sharing options...
oktiv Posted June 20, 2007 Share Posted June 20, 2007 Bump on the ability to unlock all doors at once item. I hate having to hit the G.D. button twice so my friends can ride too! Link to comment Share on other sites More sharing options...
Leonardo Posted June 21, 2007 Share Posted June 21, 2007 [quote name='iguanamafia']It used to be under the center console in years past. On the brain there was a reostat/ potentiometer that you could adjust the sensitivity with on the brain. I am guessing that all still exists.[/QUOTE] Yep, but nowadays you need the Subaru Select Monitor to adjust it. Link to comment Share on other sites More sharing options...
doobaruGT Posted November 14, 2009 Share Posted November 14, 2009 Here's one for you....and maybe I just need to open my manual...but anyway, my lock chime (beep) won't "beep" anymore. The only time it chimes is if the car is locked and I use the trunk release. Once I close the trunk, the car will chime to let me know it's locked. I like the chime bc for some reason I remember more clearly if I lock from an auditory stimulus as opposed to watching the lights flash. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
rwbareis Posted October 14, 2013 Share Posted October 14, 2013 After disconnecting the battery to fit a electric brake controller, I found that my Subaru Outback 2010 driver's side window would not automatically go up and down - IE, I had to hold the switch rather than just a momentary press. I did a reasonable bit of searching and didn't see the answer published other than in the service manual, so I have shared it here. I apologise if it is already posted and I just could not find it. From the manual: Sit in the driver’s seat and close the door.Turn the ignition switch to ON.Operate the power window main switch to open the window glass halfway.Operate the power window main switch to “UP” direction to fully close the driver’s side window glass.While the window glass is fully closed, hold down the power window switch to “UP” direction for one second.Operate the power window main switch to “AUTO DOWN” direction to check whether the window fully opens properly. NOTE: If the window does not fully open properly, repeat steps 1 to 6 It did not work for me initially, but I turned the ignition off and then on again and then normal automatic window operation was restored. Hope this is useful. Link to comment Share on other sites More sharing options...
