2.5rxliberty Posted April 27, 2006 Share Posted April 27, 2006 I dont know what is happening or how to check. The other day I washed the engine down with the battery disconnected and waited for it to dry. First start after that the engine light came on for about 1 minute and now it comes on every time you start the car at random times for about and no longer then 1 minute. It does not happen reguarly but every hour or so. Any help???? Link to comment Share on other sites More sharing options...
legacy95 Posted April 27, 2006 Share Posted April 27, 2006 y did u disconnect the battery i usually have the car running but cover the alternator and coil pack so if it is off it does not have a hard time starting Link to comment Share on other sites More sharing options...
Legacy BoB Posted April 27, 2006 Share Posted April 27, 2006 Normally its a sensor thats gone bad, Link to comment Share on other sites More sharing options...
LetItSnow Posted April 27, 2006 Share Posted April 27, 2006 You should really pull the code before expecting any answers. Link to comment Share on other sites More sharing options...
OCDetails Posted April 27, 2006 Share Posted April 27, 2006 This is why you have to be careful when you hose down the engine. It isn't made out of sugar and it won't melt if it gets a little wet, but if you get water in the wrong places then it can cause problems. You need to get the code so you know where the problem is. It could be a failing connection due to corrosion or something similar. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
2.5rxliberty Posted April 27, 2006 Author Share Posted April 27, 2006 yeah thanks i will go to subaru and get them to pull the codes. So how I go from there Link to comment Share on other sites More sharing options...
OCDetails Posted April 27, 2006 Share Posted April 27, 2006 Once you know the codes you should know what needs to be replaced. The mechanic will tell you what to do from there. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
dplacen Posted April 27, 2006 Share Posted April 27, 2006 I have washed many subaru engine down and never had a problem. With the engine on or off. I just washed the engine of my car yesterday. Link to comment Share on other sites More sharing options...
