Bez Posted April 3, 2006 Share Posted April 3, 2006 H&R has their sport springs available for the BL and I spoke with Jason at H&R Special Springs L.P. about them. The part number is 54425 and their SRP is $369 for the set of four. Jason suggested that these springs would work well with the OEM struts and that aftermarket hock absorbers were not needed. Is anyone running this combination? I have had good experience with H&R springs in the past and my Maxima SE and 1974 BMW 2002 are both riding on H&R sport springs but in both cases on after market shocks, Tokico gas-overs and Bilstein HD respectively. H&R would not give me the spring rates or K factors for the springs as this is not their policy. Does anyone know how the H&R spring rates compare with say the STi pinks? Jason suggested that the H&R coilovers would be a better solution since the spring and struts are matched, but I think that this may be overkill for a street application as I am not going to track my BL and doubt that I would ever adjust ride height once it was set. Link to comment Share on other sites More sharing options...
Bez Posted April 11, 2006 Author Share Posted April 11, 2006 Bump, must be someone running H&R springs on stock struts. Link to comment Share on other sites More sharing options...
PeterJMC Posted April 11, 2006 Share Posted April 11, 2006 Bump, must be someone running H&R springs on stock struts. Did Jason from H&R say that they had the coilovers for the '05+ Legacy available already? Here is one post on H&R springs... http://www.legacygt.com/forums/showthread.php?t=30471&highlight=H%26R Link to comment Share on other sites More sharing options...
Bez Posted April 11, 2006 Author Share Posted April 11, 2006 The Coil-overs are not available yet, but should be done testing soon according to Jason. Thanks for sending me the H&R link. Peter Link to comment Share on other sites More sharing options...
