finse Posted March 7, 2006 Share Posted March 7, 2006 It seems like spring time is almost here, and with the change in seasons I am planning finish the job I think SOA should have done at the factory, add the STi pinks & the JDM 20 mm rear sway bar After searching, it appears that the USDM Spec B has the same top hats as its JDM counterpart. That leaves the question; when I go to install the STi springs, should I have any other parts on hand? As far as the sway bar is concerned, if I replace the OEM rear sway with the JDM 20mm rear sway, should I be looking at replacing the front sway bar? If the USDM front sway the same size as the JDM front sway? Thanks, Ryan Link to comment Share on other sites More sharing options...
SC GT Posted March 7, 2006 Share Posted March 7, 2006 Re springs - You don't need anything other than what you've already got. Re front sway bar - By all accounts, the JDM and USDM LGT fronts are the same. Link to comment Share on other sites More sharing options...
finse Posted March 7, 2006 Author Share Posted March 7, 2006 Excellent, this is what I was hoping to hear. Thanks for the reply SC GT. Ryan Link to comment Share on other sites More sharing options...
scans007 Posted March 7, 2006 Share Posted March 7, 2006 Yeah, I was talk'n to RaceComp....They make specific Pinks for the SpecB, the don't drop the car quite as much as the normal STi's, but they are made for the B.......both will work.......I'll be pick'n them up sometime in the next 3 - 4 months......and 100% gonna pick up a rear sway bar...... Link to comment Share on other sites More sharing options...
finse Posted March 8, 2006 Author Share Posted March 8, 2006 Yeah, I was talk'n to RaceComp....They make specific Pinks for the SpecB, the don't drop the car quite as much as the normal STi's, but they are made for the B.......both will work.......I'll be pick'n them up sometime in the next 3 - 4 months......and 100% gonna pick up a rear sway bar...... I have the specific Pinks sitting right next to my TV, and I ordered the JDM sway this afternoon. With a little luck I should have both installed by mid April. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted March 8, 2006 Share Posted March 8, 2006 I have the specific Pinks sitting right next to my TV, and I ordered the JDM sway this afternoon. With a little luck I should have both installed by mid April. Good it has to be the right pinks or the front will not be lowered enough. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
