washburn33 Posted February 22, 2006 Share Posted February 22, 2006 I found a set of 5 Zigen Pro Racer GN+ wheels. They are 18 x 8.5 5-100 with a +48 offset. Xenonk says I need to have a +45 offset to keep the stock scrub radius. Can I just use a 3mm spacer to correct this? Link to comment Share on other sites More sharing options...
BOXRPWR Posted February 22, 2006 Share Posted February 22, 2006 something tells me that the +48mm offset might just work without a 3mm spacer...... http://i15.photobucket.com/albums/a373/BOXRPWR/DSCN9988.jpg Link to comment Share on other sites More sharing options...
Legasee Posted February 22, 2006 Share Posted February 22, 2006 they won't fit..they won't fit!! now sell them to me for 1/2 of what you paid for! j/k...they fit BOXRPWR's car so it should be alright In Taiwan now... Link to comment Share on other sites More sharing options...
washburn33 Posted February 22, 2006 Author Share Posted February 22, 2006 Can someone answer my original question Link to comment Share on other sites More sharing options...
robsontuning Posted February 22, 2006 Share Posted February 22, 2006 If you put spacers on the car you will actually decrease the offset, not increase it. If you have a 48 offset it will fit, and you would not have to go through the trouble of spacers and installing new lugs that are long enough Link to comment Share on other sites More sharing options...
luv2drive Posted February 22, 2006 Share Posted February 22, 2006 Just make sure to get very oversized tires ftw. Link to comment Share on other sites More sharing options...
zildjiank Posted March 5, 2006 Share Posted March 5, 2006 Sorry, this is off topic... But, Boxer, that car looks like a monster... And dead sexy w/ those calipers... Link to comment Share on other sites More sharing options...
IanKen Posted March 5, 2006 Share Posted March 5, 2006 something tells me that the +48mm offset might just work without a 3mm spacer...... +1 They are nice wheels. No spacers needed. Link to comment Share on other sites More sharing options...
SWortham Posted March 5, 2006 Share Posted March 5, 2006 I found a set of 5 Zigen Pro Racer GN+ wheels. They are 18 x 8.5 5-100 with a +48 offset. Xenonk says I need to have a +45 offset to keep the stock scrub radius. Can I just use a 3mm spacer to correct this? It's generally good to keep your scrub radius close to stock because you can adversely affect handling, torque steer, etc if you play with extreme offsets. But a difference of +/- 3mm is very little... so I wouldn't worry about it from that standpoint. Link to comment Share on other sites More sharing options...
X2Board Posted March 8, 2006 Share Posted March 8, 2006 something tells me that the +48mm offset might just work without a 3mm spacer...... What size tires are you running on those? I think they will look great on my ABP wagon. Thanks, X2 Link to comment Share on other sites More sharing options...
