-HEF- Posted January 31, 2006 Share Posted January 31, 2006 not sure if those goes in this forum... anyone else have the problem that when you turn the steering wheel all the way right or left till it doesn't go anymore, that you get a screeching noise like a loose belt would sound like? i rear-ended someone and only noticed this problem after i got my car back from the shop. it is going back, but i just wanted to know what the issue is before i take it in. Link to comment Share on other sites More sharing options...
GT-L Posted January 31, 2006 Share Posted January 31, 2006 you know i have the same thing! although i did not rear end no one, i just noticed it one day. makes like a *chew chew chew* sound, haha. anyways im taking care of it soon. Link to comment Share on other sites More sharing options...
francesto1 Posted March 28, 2011 Share Posted March 28, 2011 I have a Legacy 08, it makes the same noise when the steering wheel is turned all the way. I found out the reason for the noise is that a rotatory part (not sure what it is) attached to the belt, stops moving and creates the noise. I just bought the car and the belt it has is not OEM. I'm thinking on changing to a Subaru belt and see what happens, maybe this one is too tight....also, the noise is more frequent in cold weather. Link to comment Share on other sites More sharing options...
