doogdog Posted January 29, 2006 Share Posted January 29, 2006 Was in an accident in December, body shop had to take the driver's door apart to remove the door handle for painting. They did an excellent job on the repairs and paint, however, in the cold (sub 25 degrees F) the lock keeps freezing. It's been back once to the body shop, I watched them take the door card off and lube up everything with white lith grease. Any suggestions on what could be causing this? Does anyone have a cutaway of the driver's door, maybe some weatherstriping didn't get installed? I can unlock the door only from the inside, the remote, exterior lock with key, and the electric unlock button do not work when it freezes. The only way fro me to get in is bu manually unlocking the door with the slide by the interior driver's door handle. Of course once the car is warmed up the problem fixes itself. Any help would be appreciated. Rick Link to comment Share on other sites More sharing options...
mwiener2 Posted January 29, 2006 Share Posted January 29, 2006 get the whole mechanism replaced under warranty or under warranty of the body shop from the accident moved to warranty My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
BDII Posted January 29, 2006 Share Posted January 29, 2006 let us know what your dealer/bodyshop dooes for you. I have never stuck the key in the lock since i have owned the car!! Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted January 29, 2006 Share Posted January 29, 2006 Isn't there supposed to be a waterproof shield that goes over the assembly? Maybe check the vacation pix, but that's pretty common- maybe it was left out in the reassembly. Link to comment Share on other sites More sharing options...
doogdog Posted January 30, 2006 Author Share Posted January 30, 2006 Why is this in warranty, this is related to repairs done by a body shop? Anyway an update... The body shop took the door apart this morning and couldn't find anything obvious. They're replacing the actuator and door lock assembly on their dime. I'll keep everyone updated.Rick Link to comment Share on other sites More sharing options...
melayout Posted January 30, 2006 Share Posted January 30, 2006 Good luck and this IS NOT WARRANTY. I keed I keeed Link to comment Share on other sites More sharing options...
mwiener2 Posted January 30, 2006 Share Posted January 30, 2006 it's under the warranty of the body shop's repairs My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
melayout Posted January 30, 2006 Share Posted January 30, 2006 Technical bullsh!t. Judge, note my objection. I keed I keeed Link to comment Share on other sites More sharing options...
mwiener2 Posted January 30, 2006 Share Posted January 30, 2006 ok, well where do you think it belongs? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
melayout Posted January 30, 2006 Share Posted January 30, 2006 You're technically right, but that's just wrong. My 8 ball says Exterior/Asthetic or Subaru Outback. I keed I keeed Link to comment Share on other sites More sharing options...
doogdog Posted February 22, 2006 Author Share Posted February 22, 2006 Here's an update on the freezing doorlock issue... Brought it to the body shop a few weeks ago, they couldn't see anything wrong so they ordered a new doorlock assembly, actuator, and linkage. It was installed today. They seem to think that there is a plastic bushing that was a little worn between the actuator and doorlock. They seem to think that when it got cold it would bind up just enough to prevent the lock from unlocking (could always unlock manually). All was replaced today, also the window was adjusted up slightly to prevent my 80+ mph wind noise. Time will tell if this fixes things, I will keep taking it back until they get it 100%. BTW, this doesn't belong in warranty issues & problems:icon_bigg. Rick Link to comment Share on other sites More sharing options...
