BLACKeNeD Posted January 28, 2006 Share Posted January 28, 2006 I decided to make a mount in the same place the proclip uses. I just bent some scrap metal. I will get the pro clip when I have the time ot order it online. I still have to order an FM modulator and the metra antenna adapters anyway. It is just running through the Skyfi's internal FM modulator. http://images16.fotki.com/v276/photos/5/58182/3154408/DSC_1530-vi.jpg I ran the Antenna to the Third brake light tray, and it fits well. http://images15.fotki.com/v265/photos/5/58182/3154408/DSC_1529-vi.jpg The position is not ideal, but I still have access to all the buttons and knobs, so it's not too bad. In any case, it's way better than this... http://images15.fotki.com/v261/photos/5/58182/2180131/DSC_1518-vi.jpg Link to comment Share on other sites More sharing options...
Boulderguy Posted January 28, 2006 Share Posted January 28, 2006 Slick location for the antenna. Link to comment Share on other sites More sharing options...
andrew.anderson Posted January 28, 2006 Share Posted January 28, 2006 Has anyone tried to integrat it into the cubby between the vents? Would probably be alot of work but would look good. Link to comment Share on other sites More sharing options...
Boulderguy Posted January 28, 2006 Share Posted January 28, 2006 There are a number of those around if you search. Link to comment Share on other sites More sharing options...
andrew.anderson Posted January 28, 2006 Share Posted January 28, 2006 There are a number of those around if you search. Well you answered my question and I did not have to search. Less work for me. Link to comment Share on other sites More sharing options...
Boulderguy Posted January 28, 2006 Share Posted January 28, 2006 I meant I'd seen them but don't know any specifics - I don't do that "search or die" bit. Link to comment Share on other sites More sharing options...
andrew.anderson Posted January 28, 2006 Share Posted January 28, 2006 Believe it or not no sarcasm. You did answer my question, people have tried it, and I am lazy when it somes to searching. That was enough to motivate me to search and there was some cool stuff out there. Link to comment Share on other sites More sharing options...
BLACKeNeD Posted January 28, 2006 Author Share Posted January 28, 2006 I prob could have hidden the wire completely by drilling a small hole in base of the brake light plate, but it would have doubled the time it took me to do everything. Link to comment Share on other sites More sharing options...
ntadime Posted January 30, 2006 Share Posted January 30, 2006 I tried that location and had a lot of drop outs. I have the antenna for my Roady 2 on the trunk lid behind the spoiler. Cable goes over the inner lip, under the truck lid interior cover, down the hinge, in thru the pass thru , behind the top of the rear seats(tucked in so it can't be seen), along the edge of the carpet tucked under the side molding, under the dash and there it is. No drop outs, never unless I loose the southern horizon. Link to comment Share on other sites More sharing options...
scans007 Posted January 30, 2006 Share Posted January 30, 2006 Nice Nipple Great local.....hope you don't mind, I'll steal that idea when I get mine in Link to comment Share on other sites More sharing options...
direavenger Posted February 10, 2006 Share Posted February 10, 2006 Has anyone tried to integrat it into the cubby between the vents? Would probably be alot of work but would look good. The SkyFi is too large to fit in the cubby with the docking cradle and all. The only one that will fit with little/no modification is Terk XM Commander. The Roady2 is close but no cigar. I did it with my Audiovox Xpress, but lost the cubby door. It is just a prototype with cardboard/leatherette, but I think the finished product will look good. http://legacygt.com/forums/showthread.php?t=25544&highlight=xpress The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
Mui01 Posted February 10, 2006 Share Posted February 10, 2006 I prob could have hidden the wire completely by drilling a small hole in base of the brake light plate, but it would have doubled the time it took me to do everything. Dude, how about mounting inside the trunk? Don't know if it affects the signal. Link to comment Share on other sites More sharing options...
direavenger Posted February 10, 2006 Share Posted February 10, 2006 Dude, how about mounting inside the trunk? Don't know if it affects the signal. XM is pretty heavily reliant on a line of sight to the sky. Putting it inside of a metal box isn't going to help the signal much. The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
BLACKeNeD Posted February 10, 2006 Author Share Posted February 10, 2006 XM is pretty heavily reliant on a line of sight to the sky. Putting it inside of a metal box isn't going to help the signal much. Link to comment Share on other sites More sharing options...
