steveey Posted January 16, 2006 Share Posted January 16, 2006 It all started when my passenger rear turn signal light went out. When I went to replace the bulb the socket was all melted and charred. I bought a new socket and bulb and realized that the turn signal works when the lights are not on. When the lights are on just the passenger side rear tail light doesn't work. I don't know what to do and need help before I get a ticket. Link to comment Share on other sites More sharing options...
Xenonk Posted January 16, 2006 Share Posted January 16, 2006 did you get the wires crossed up when you spliced in the new harness? that's what it sounds like to me. Keefe Link to comment Share on other sites More sharing options...
meier motor sports Posted January 16, 2006 Share Posted January 16, 2006 since he said it was melted before he replaced it i would bet it didnt work before and there is a short between wires some where else Link to comment Share on other sites More sharing options...
Xenonk Posted January 16, 2006 Share Posted January 16, 2006 ^ my guess is that the owner used higher wattage bulbs and burnt the harness.. after replacing the harness, somewhere along the way, the wires were crossed up when splicing the new harness back in.. typically, a normal harness wouldnt fry up like that unless there was a higher drawing bulb was used.. how did the wire fry up in the first place? Maybe you should take the car back to the dealer to get the entire wiring looked at.. it could go all the way to the fuse, but I doubt it since you say that the signal works when the lights are not on... Keefe Link to comment Share on other sites More sharing options...
mccorry Posted January 16, 2006 Share Posted January 16, 2006 Warning... ot! ***** What car is that in your avatar, steveey? Link to comment Share on other sites More sharing options...
steveey Posted January 17, 2006 Author Share Posted January 17, 2006 did you get the wires crossed up when you spliced in the new harness? that's what it sounds like to me. i had it checked. wires were jammed, charred. that is why there was a sharing of electric current with the turn signal. oh, well... mccory.. i can't tell.. i just know it's hot! Link to comment Share on other sites More sharing options...
Aryx Posted May 10, 2006 Share Posted May 10, 2006 Warning... ot! ***** What car is that in your avatar, steveey? Looks like the Mad Max's 'Interceptor' which was, I think, a Ford Falcon. Someone correct me if I'm wrong Link to comment Share on other sites More sharing options...
pillboy Posted May 11, 2006 Share Posted May 11, 2006 I think Aryx is right. An Australian Ford Falcon. It is still ugly. Link to comment Share on other sites More sharing options...
