Entityultima Posted June 7 Share Posted June 7 Unfortunately my Legacy has decided that gears are optional and its time for a swap. The transmission that's in there right now is a TZ102ZA2AA-MH according to the sticker. With that being said obviously I need something that'll bolt in, but what cars should I look for parts? Is there a cutoff of model year before I start having fitment issues? Appreciate all information as I'm going in completely blind and there's not much for information online that's not conflicting. Thank you, Entity from BC Link to comment Share on other sites More sharing options...
arse_sidewards Posted June 10 Share Posted June 10 God forbid you include useful info like manual vs auto. But the TL;DR of it is that any phase 1 transmission will bolt right in. Link to comment Share on other sites More sharing options...
Entityultima Posted June 10 Author Share Posted June 10 My apologies, looking for auto transmissions. How can i tell if they are phase 1? Going in completely blind here. Link to comment Share on other sites More sharing options...
arse_sidewards Posted June 11 Share Posted June 11 For your purposes anything 98down will work. The transition from phase 1 to phase 2 should coincide with the change from 4-bolt bell-housing to 6-bolt. Depending on what you get you may wind up needing to track down a rear diff to go with the new trans as most of the later ones are 4.10 whereas yours is 3.90. Swapping the ring and pinion bits from your old trans to the new one is doable but it's about the same amount of work as doing a rebuild so not really worth it. Link to comment Share on other sites More sharing options...
