rosta Posted December 29, 2005 Share Posted December 29, 2005 and end up leaving with 2 pairs of Polk db650's! The "buy one get another for 50% off" is still running. My initial intent was to pick up some Hushmat and leave. Silly me had to poke around and saw the signage for the Polk's. I had planned on getting something for rearfill and use a pair of Nakamichi SP-65C's I had stowed away for many years. The Nak's are pretty deep (2.5") and probably would sound much better with a proper amp. Now that I have 2 pair of db650's and plan to use stock power supply until I sort out the other components, should I leave my Nak's boxed up until I can provide them with more juice or should I install them and sell the second pair of Polk's? Looking forward to any and all words of wisdom. Ross Link to comment Share on other sites More sharing options...
Sub_Free Posted December 30, 2005 Share Posted December 30, 2005 Have you installed these yet?How do they sound?Did you need to use a spacer? Link to comment Share on other sites More sharing options...
see_obxt Posted December 30, 2005 Share Posted December 30, 2005 I just installed a pair of db650s and a pair of the db570s in my son's car. Also an amp and a 10" Rockford Fosgate sub. The Polks run off a Pioneer unit and the sub off a 220 watt amp. I'm running the sub off one channel at 128 amp 2 ohm. The Polks are great even from a standard stereo amp. They will fit my OBXT but I believe you need a 1/2" spacer in the fronts. Link to comment Share on other sites More sharing options...
rosta Posted December 30, 2005 Author Share Posted December 30, 2005 install will take place this weekend. i think i'm going with the "rip the o.e. speakers apart and use them as spacers" route. i reserve the right to change my mind once the panels are off and i can see what i'm in for. i'm probably more concerned with the hushmat. based on the "Sound Deadening FAQ ",i only bought 4 sq ft of material. i figured that should be enough to cover the 20-30% of the front doors. we'll see but it seems others have gone with the 80% coverage technique. i suppose it's just deeper pockets. Have you installed these yet? How do they sound? Did you need to use a spacer? Link to comment Share on other sites More sharing options...
