Dsfa Posted December 27, 2005 Share Posted December 27, 2005 I got a PIAA rear wiper for Xmas and I can't install it! The wiper camer with four adapters and none of them work. Any suggestions? Or is there any other aftermarket options ? Thanks /..........Jim Link to comment Share on other sites More sharing options...
G.T.Subie Posted December 27, 2005 Share Posted December 27, 2005 Do you mean "WIPER". Denial is your best friend Link to comment Share on other sites More sharing options...
Dsfa Posted December 27, 2005 Author Share Posted December 27, 2005 Yes I should done a seach first LOL Link to comment Share on other sites More sharing options...
Dsfa Posted December 27, 2005 Author Share Posted December 27, 2005 Do you mean "WIPER".Thanks for your quick response Link to comment Share on other sites More sharing options...
red beast Posted December 30, 2005 Share Posted December 30, 2005 i got piaa blades, then realized i should have just ordered the refills. try just replacing the blade. Link to comment Share on other sites More sharing options...
Xenonk Posted December 30, 2005 Share Posted December 30, 2005 I replaced mine just fine, it's the C1 adapter.. it should work just fine? Keefe Link to comment Share on other sites More sharing options...
TYNY Posted December 30, 2005 Share Posted December 30, 2005 yeah the smaller size adapter is all you need. bought the front blades and refills, ended up using only the refills cause i ike the stock arm with the wind-piece/deflector. Link to comment Share on other sites More sharing options...
Dsfa Posted December 30, 2005 Author Share Posted December 30, 2005 I replaced mine just fine, it's the C1 adapter.. it should work just fine?C1? Are you guys taking about the rear wiper? Do you think that the PIAA blade refill will fit the stock blade? Link to comment Share on other sites More sharing options...
Xenonk Posted December 30, 2005 Share Posted December 30, 2005 ^yea, it should, if not, cut it to length, it's only rubber/silicon Keefe Link to comment Share on other sites More sharing options...
