mike8891 Posted December 27, 2005 Share Posted December 27, 2005 how hard is it to replace the bulbs for the headlights? do i have to take anything out to get to the bulbs? thanks for the help Link to comment Share on other sites More sharing options...
Xenonk Posted December 27, 2005 Share Posted December 27, 2005 please do a search, someone already mentioned the information that you ask of, see the exterior forums or walkthrough forums for this info.. but to make it short for you since you are new member: Driver side= -remove the windshield washer fluid tube out of your way by popping out the clip that holds the tube in place -undo the cover behind the headlight that secures the connectors from dust, to remove it, you turn/twist off the cover from the headlight assembly -undo the connector by pinching the latch from the headlight -the headlight I believe is held by the spring clip driver side: no special items to remove, follow the driver side instructions. it's very straight forward. Keefe Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted December 27, 2005 Share Posted December 27, 2005 here you go mike: http://legacygt.com/forums/attachment.php?attachmentid=12716&d=1134695339 Link to comment Share on other sites More sharing options...
Xenonk Posted December 27, 2005 Share Posted December 27, 2005 moved to walkthroughs/maintenance Keefe Link to comment Share on other sites More sharing options...
pfrancz Posted May 18, 2011 Share Posted May 18, 2011 Thanks, for the info: We have a bulb out on a '08 legacy, drivers side, and looked for the instructions in the forum. We appreciate you all posting these tips here, possibly similar, from my inspection look today. All the Best Link to comment Share on other sites More sharing options...
OptimumLGT Posted November 18, 2011 Share Posted November 18, 2011 I've got a bad driver's side head light that I just replaced and it's still out. How likely is it to be a wire vs. a connector issue? Anyone know how far back the wireing harness goes? I've got an Amp/volt meter. Link to comment Share on other sites More sharing options...
underpowerd Posted November 18, 2011 Share Posted November 18, 2011 i'd recheck the new bulb (lgt can eat bulbs, and sometimes they do blow immediately upon replacement) -- if sound, i'd check all related fuses/relays, connectors before going after the wiring in that tight corner. Link to comment Share on other sites More sharing options...
