ssbtech Posted October 16, 2023 Share Posted October 16, 2023 05 Outback XT with soft/long pedal travel. Pads/Rotors good. Suspect failed seal or pitted bore in master cylinder. Looking at images I see on the side where it bolts up to the booster, there's a seal and a small hole - see attachment. I don't see this on videos I've seen bench bleeding the BMC, and the Subaru service manual shows bleeding it by installing it to the car, placing a plastic bag over it and covering the outlets with your fingers while someone pumps the brake. Can these not be bench bled in the traditional manner? Link to comment Share on other sites More sharing options...
