jrvp20 Posted August 29, 2023 Share Posted August 29, 2023 On my 08 facelift bl5 legacy the o2 sensor was not giving a reading was stuck on 14.70 however the car was fueling fine. Got around 500km on a tank. I changed the o2 sensor a used sensor tho. However now the car burning gas alot and this morning the car is stuttering when pulling off. I disconnected the sensor and its driving normal however the check light is on. I dont have the funds to purchase a new sensor atm. Would it be okay to drive the car? Link to comment Share on other sites More sharing options...
relative4 Posted August 29, 2023 Share Posted August 29, 2023 Sure, if you want to destroy your catalytic converter. Put the old sensor back on and do some more diagnosis before throwing parts. Link to comment Share on other sites More sharing options...
jrvp20 Posted August 29, 2023 Author Share Posted August 29, 2023 (edited) What else may cause the front O2 not to read if the sensor itself not bad? I was going to buy a new sensor and install it Edited August 29, 2023 by jrvp20 Link to comment Share on other sites More sharing options...
relative4 Posted August 29, 2023 Share Posted August 29, 2023 1. What symptoms started you down this road? Particularly given you say it was fueling fine? 2. How did you determine the sensor is not reading? The O2 sensor does not read 14.7; that's a calculated A/F ratio that may be highly suspect depending on what's giving you that result. An O2 sensor gives a cycling voltage. Did you graph the O2 sensor output? Link to comment Share on other sites More sharing options...
jrvp20 Posted August 29, 2023 Author Share Posted August 29, 2023 When the car went to tune the tuner said the o2 sensor not giving a reading. Its stuck on 14.70 . He recommended to change it. The car was giving no symptoms of a issue. Thats why i thinking just to put back the old sensor. Link to comment Share on other sites More sharing options...
relative4 Posted August 29, 2023 Share Posted August 29, 2023 Well then, gonna need a lot more info. Mods, logs, etc. Link to comment Share on other sites More sharing options...
m sprank Posted August 30, 2023 Share Posted August 30, 2023 (edited) Maybe you have a bad heater circuit on the O2 that reads 14.7. Then maybe the used replacement is actually working and now your car is not running properly because it needs a tune. You need data to know. Edited August 30, 2023 by m sprank Link to comment Share on other sites More sharing options...
