GTCanada Posted December 25, 2005 Share Posted December 25, 2005 I swapped out the original 7kg springs for 6kg. I found the 7kg too stiff for daily life. I have only had the 6kg in for 2 days, and the Holidays are limiting my drive time, but initial impressions (with the dampers at 50% of max stiffness) are that the 6kg are a much better setup for me with less impact harshness and bounciness over poor asphalt. The 7kgs didn't have enough compliance for hard cornering in bumpy turns. The 6kgs are much better. Tom Link to comment Share on other sites More sharing options...
Xenonk Posted December 25, 2005 Share Posted December 25, 2005 well, did you turn down the shocks for the 7kg springs?? because you are only changing 56 lbs/in.. did you also change the preload on the 7 prior to changing to softer springs? Keefe Link to comment Share on other sites More sharing options...
GTCanada Posted December 26, 2005 Author Share Posted December 26, 2005 Yes I did. Tom Link to comment Share on other sites More sharing options...
whoopwhoop Posted January 7, 2006 Share Posted January 7, 2006 well that about says it all!!! Any more driving on the car??? Link to comment Share on other sites More sharing options...
Xenonk Posted January 7, 2006 Share Posted January 7, 2006 ^ soft ride? I run with 8/6 and I will be going to a set of 12/10 or 14/12 for my Zeals.. and 8/6 isnt bad at all for daily driving.. well, not on the Zeals anyways.. I havent messed around enough with the Ksports to know where the sweet spot is for those coilovers.. too bad I can't have a shootout with GPMoto, Tein, Blitz, HKS, Zeal, Ksport, Bilstein, and even STi's version and just go for a drive in all of them to see which one out performs which in different categories such as: ride compliance maximum g-force usable range of adjustments control quality track time performance Keefe Link to comment Share on other sites More sharing options...
robsontuning Posted January 7, 2006 Share Posted January 7, 2006 DMS 50mm still made a comfortable daily driver, and great for the autocross Link to comment Share on other sites More sharing options...
RobY Posted January 7, 2006 Share Posted January 7, 2006 Keefe If you are ever up by me or me down by you... your more than welcome to try my GPmoto setup. Im gonna try to make the NASIOC tail of the dragon meet this year. Unless we get enough intrest here to start our own meet. Link to comment Share on other sites More sharing options...
Xenonk Posted January 8, 2006 Share Posted January 8, 2006 no doubt, I'll try to make it to another Dragon meet if there is one around the fall season for 2006.. Keefe Link to comment Share on other sites More sharing options...
