Driver72 Posted August 12, 2004 Share Posted August 12, 2004 Was searching around and came upon these wheels (hopefully it will post the site): [img]http://www.veloxperformance.com/Images_U/rev10-silver500.jpg[/img] Anyway, these wheels look pretty great. They are 17x7 and weigh an unbelievable 11.5 pounds each. They have a load rating of 690. Is that okay? What's the load rating of the stock wheels? Thanks Link to comment Share on other sites More sharing options...
Ninjapimp Posted August 12, 2004 Share Posted August 12, 2004 I've never heard of them and it almost sounds too good to be true. I'm a skeptic. Are they forged? If they aren't, i'd be scared of strength. Link to comment Share on other sites More sharing options...
SUBE555 Posted August 12, 2004 Share Posted August 12, 2004 I can't actually get any details on their products through their site. They do have some nice looking wheels, but until I've seen more data, I'd be very cautious. 690lb load rating won't be enough, at least that design. Might be fine for a little VW Rabbit or something, but 690x4= 2760lbs. Not nearly enough, then throw in cornering forces! They might be light, but not strong enough for the Subaru's. If more data was available, particularly on their manufacturing techniques, they might get at least a single look from me. Couple nice designs: [img]http://www.veloxperformance.com/Images_U/ZETA%20K-bronze150.jpg[/img] [img]http://www.veloxperformance.com/Images_U/ZETA%208-bronze150.jpg[/img] Link to comment Share on other sites More sharing options...
Xenonk Posted August 12, 2004 Share Posted August 12, 2004 Velox PG series are the light ones.. I think they are HIGH (10-ton press vs. typical 8-ton) pressure casting still.. and for the money, they are comparitive to SSR Competitions.. the weight is fairly good for what they are.. 690kg is typical weight limit. Stock loading weight is about the same. I think SSRs Comps come 1/2" wider and have the same weight. SSRs are also made better than Velox by a hybrid casting system. Velox have some light rims, but double check your tire sizing to match the wheel width. Sube555, you forgot that the tire shares the load.. hence the tire pressure load weight (varies with tire sizing and manufacturer). Most aftermarket rims are measured in kg, not lbs. So the math is really 690kg x 2.2lbs/kg x 4 rims = 6072 lbs. Keefe Keefe Link to comment Share on other sites More sharing options...
Driver72 Posted August 12, 2004 Author Share Posted August 12, 2004 Thanks guys, and keefe. I'll look into the SSR Comps. too. I'm also amazed by how few manufacturers list the weight of their wheels on their sites. Most probably don't because they know if they make heavy wheels, people might look elsewhere. If consumers don't know the weight, they might not even bother to ask. Link to comment Share on other sites More sharing options...
axis008 Posted August 12, 2004 Share Posted August 12, 2004 If my memory serves me correctly, they are a sister brand of Axis Wheels. -ben Link to comment Share on other sites More sharing options...
SUBE555 Posted August 12, 2004 Share Posted August 12, 2004 Well if it's kg, then it make a lot more sense Xenonk. Wonder why a company would otherwise make a wheel that would be so underrated but in so many styles. Forgot about the tire aspect also. I was thinking each had to be able to carry the same load. My bad. Just rarely see too many wheels list their load ratings, at least on cars where not too many people load their vehicles that much. That is unless you have a Jetta, Home Depot, and a camera. ;) Link to comment Share on other sites More sharing options...
axis008 Posted August 13, 2004 Share Posted August 13, 2004 [quote name='SUBE555']Well if it's kg, then it make a lot more sense Xenonk. Wonder why a company would otherwise make a wheel that would be so underrated but in so many styles. Forgot about the tire aspect also. I was thinking each had to be able to carry the same load. My bad. Just rarely see too many wheels list their load ratings, at least on cars where not too many people load their vehicles that much. That is unless you have a Jetta, Home Depot, and a camera. ;)[/quote] Puts a new meaning to two-wheeled-drive! :P -ben Link to comment Share on other sites More sharing options...
