CBRRICH Posted June 14, 2023 Share Posted June 14, 2023 Recently I did a timing belt, Water Pump, and Thermostat. Car has been running fine, Temperature gage right in the middle. Shortly after, I noticed on cooldown the top radiator hose would collapse. I topped it up multiple times to eliminate as much air as possible. I noticed the bottle is still at the "Full" line where it was when I filled the system and has not moved up or down (when cold) suggesting that not much movement of coolant there. I bought a new OEM radiator cap for the radiator, still doing it. I disconnected the overflow line from the radiator filler neck to eliminate the possibility of a plug in the overflow pipe, no change. Collapsing hose, new radiator cap, water pump and Tstat are all OEM Subaru parts. Now I'm stumped: If the radiator cap is supposed to backflow to relieve a vacuum and return overflow coolant to the radiator why is the hose collapsing? Link to comment Share on other sites More sharing options...
