legacyshawn Posted May 15, 2023 Share Posted May 15, 2023 (edited) I just JDM swapped my 2008 3.0R. 8k miles after doing the timing chain and water pump, the head gasket blew (exhaust pressurizing the coolant). Engine has 182k miles. JDM parts listed have between 40-60k miles. Everything is what you offer. Figured I’d put it up here in case anyone’s wants it. 1) Engine with new timing chain kit installed (180k on engine and 8k on timing chain kit). Plenty of new bolts for the front timing chain cover still in bag since I just reused them. I can get you the complete part number list if you want. USDM engine block and heads (no internal damage besides head gasket failure) sensors and solenoids fair game. Also have rear crank position plate and good condition flex plate. $600 OBO Engine + timing chain kit (8k miles installed) Includes: -left and right tensioner -Water pump -all new timing chain guides with all screws 2) Subaru Power steering pump 60k miles $150 OBO 3) Subaru Alternator 60k miles $100 OBO 4) 6x ignition coils (180k miles) no issues $50 OBO 5) Factory injectors x6 180k miles $80 OBO 6) EGR pipes and solenoid $80 OBO 7) JDM intake, the only difference is brake boost connector is on passenger side. $80 OBO 8 ) OEM electronic throttle body. 60k miles. $80 OBO 9) OEM Harmonic Balancer, crank shaft pulley. 60k miles $40 OBO Edited June 10, 2023 by legacyshawn Link to comment Share on other sites More sharing options...
legacyshawn Posted June 10, 2023 Author Share Posted June 10, 2023 New parts and pictures added. Link to comment Share on other sites More sharing options...
