Fuzzybaseball58 Posted April 28, 2023 Share Posted April 28, 2023 Electrical guy is telling me that my ABS module seems to be causing some CAN communication errors, will used parts need to be programmed, or can I just pop it on and go? Also if anyone has one in good condition let me know, I'll also be looking on the marketplace here. Link to comment Share on other sites More sharing options...
m sprank Posted May 2, 2023 Share Posted May 2, 2023 Requires no programming. But its not exactly "pop it on and go". You will need to bleed the entire brake system thoroughly at a minimum. Link to comment Share on other sites More sharing options...
Fuzzybaseball58 Posted May 2, 2023 Author Share Posted May 2, 2023 Thanks for the insight, I was planning on just stealing the computer part and leaving the original pump on, is that going to cause any hiccups? I had another parts guy telling me that if I replace the pump and the computer together it won't need programming but if I just steal the module it would. Also the subaru dealer said it would need to be programmed, so I'm getting a lot of conflicting information. Link to comment Share on other sites More sharing options...
m sprank Posted May 2, 2023 Share Posted May 2, 2023 (edited) LOL. If you use the correct part there is no issue. Programming an ABS ECM and/or VDC requires an SSMII. Most times the tech is using the tool to verify the correct part was installed. There were TSB's over time that required a new file be uploaded (reprogram) into the ABS ECM/VDC. If you try to replace with a used part you may very well experience issues and that would require a "re-programming" if it can be done. If you use the exact part number from the exact model year and transmission you should be good. Repair Procedure: 1. Turn off the ignition switch. 2. Disconnect the negative terminal from the battery. 3. Disconnect the air intake duct from the air box. 4. Remove the air cleaner case from the inner fender. Removal of ECU: Note: When removing the ECU, the brake pipes remain connected. Disconnect all electrical connections from the ECU (top and bottom). Remove the two installation bolts (M8) from the bracket of the hydraulic unit and the ECU assembly. See Fig. 1. Lift the hydraulic unit and the ECU assembly from the bracket by about 5 cm (0.2 inches) and support it with a small piece of wood. Caution: Be careful not to deform the brake pipe during this procedure. Unlock the connector for the motor power source and disconnect the connector as shown in Fig. 2. Remove the six torx head screws (T20) which join the hydraulic unit and the ECU. Note: Do not reuse the torx head screws once they are removed. Remove the ECU from the hydraulic unit by gently pulling it. See Fig. 3. Note: Do not insert anything into the gap between the ECU and the hydraulic unit. Do not pry the ECU, but pull it straight from the hydraulic unit. Do not reuse the seal from the ECU. Installation of New ECU: Confirm that the sealing surface of the hydraulic unit is clean. Note:a. Do not machine the sealing surface.b. If the sealing surface is damaged, replace the ECU as well as the hydraulic unit and the ECU assembly with a new one.c. Clean dust or foreign material from the sealing surface with a clean cloth and alcohol.d. Do not blow compressed air onto the ECU surface or the hydraulic unit In order to prevent damage on the valves protruded from the hydraulic unit, do not tilt the ECU against the hydraulic unit when assembling. Install the new ECU. Temporarily tighten the six screws by hand. Note: Do not reuse the screws that were previously removed from the ECU. Tighten the six screws in the exact order shown in Fig. 2; use the specified tightening torque of 2.65 +/- 0.30 Nm(1.95 +/- 0.22 ft.-lbs.) (26.4 in.-lbs.). Make sure the screws are securely tightened by visually confirming that there is no clearance between the ECU and the hydraulic unit. Connect the motor power source connector to the ECU. Note: Confirm that you hear a clicking sound when locking the connector lock. Install the hydraulic unit and the ECU assembly onto the bracket and tighten the two nuts with a tightening torque of 18 +/- 5Nm (13.28 +/- 3.69 ft.-lbs.) (44.28 in.-lbs.). Note: Securely attach the damper under the hydraulic unit with the hydraulic unit and the bracket. Reconnect the ECU harness connector with the ECU. Restoration of Surrounding Parts: Install the air cleaner case. Install the air intake duct. Connect the negative terminal to the battery. Testing After Replacement: Confirm that the ABS warning light comes on normally and then turns off when the ignition switch is turned on. Connect the select monitor and confirm in the first display that the model year, driving system and transmission system are correct. Confirm that the ABS warning lamp does not light when starting the engine and driving up to more than 12.5 mph (20 km/h). Note: If something abnormal was found in the above three testing procedures, follow the repair instructions described in the diagnostic procedures of the vehicle’s service manual. Courtesy of ALLDATA. Edited May 2, 2023 by m sprank Link to comment Share on other sites More sharing options...
m sprank Posted May 2, 2023 Share Posted May 2, 2023 Here is another: ad0adab3-6667-4eb1-b8b4-f87d4475310a_abs_replacement.pdf Link to comment Share on other sites More sharing options...
Fuzzybaseball58 Posted May 5, 2023 Author Share Posted May 5, 2023 Thanks for writing all that out, it's super helpful! Link to comment Share on other sites More sharing options...
m sprank Posted May 5, 2023 Share Posted May 5, 2023 Not a problem, good luck. Link to comment Share on other sites More sharing options...
