Warm_N_Moist Posted April 6, 2023 Share Posted April 6, 2023 Hello, i ve been reading the forum on about how to change from 5x100 to 5x114.3. So far got kinda lost. I have to get sti front hubs and tribeca for the rear? My reason is that i where i live there are almost no 5x100 bbs wheels and currently i have some 5x114 2005 sti wheels. I have some 25mm inch adapters 5x100 to 5x114 but i think if i can just swap hubs from an sti id rather do that. I wish to know if i can just swap the hubs of an sti( which year?) And just plug and play to 5x114.3 both front and rear. A list of parts with year would be lovely thanks. Link to comment Share on other sites More sharing options...
Pleides Posted April 7, 2023 Share Posted April 7, 2023 You would need a hub adapter or a few other parts swapped (I believe the knuckles, entire brake set, and axles and rear diff?). This is a common conundrum during 6-speed swaps. Using almost any STi transmission creates this conversion as a requirement. You're gonna be paying out the ass for STi brakes, more likely than not. It isn't worth it. Link to comment Share on other sites More sharing options...
NORULZleggy Posted April 7, 2023 Share Posted April 7, 2023 9 hours ago, Pleides said: You would need a hub adapter or a few other parts swapped (I believe the knuckles, entire brake set, and axles and rear diff?). This is a common conundrum during 6-speed swaps. Using almost any STi transmission creates this conversion as a requirement. You're gonna be paying out the ass for STi brakes, more likely than not. It isn't worth it. I can tell you right now if you want STI brakes, it is going to cost you. If you do it yourself including buying a decent set of working Brembo's, that the bolts are not stripped, new rotors, brake adapters, parking brake adapters, Break lines for STI swap, and rear 190mm drum kit, I will guess it will be: 1700 (Might be working good, and need rebuilt) - F&R 900 - Rotors/pads Brackets - 500 Total - 3100 -3700 Now I did it the correct way. I saved up for about a year and a half knowing it was not going to be cheap. I am also a part dealer and get my stuff about 45% off. I also did not want to cut corners and wanted to pay my shop to do it. Its is costing me about 2500 or less, that is including 750 of labor, and they refreshed my calipers to make sure they are in good condition. This includes everything, New DBA slotted, Hawk pads, STI conversion steel braided lines, Rear brake show adapters to run STI rotors, ISC suspension 5x100 spacers to clear wheels and so on to bolt the calipers on to the car with ease. My 18x8s will clear them, but my 17x8 inch Enkie's TS-5s might not. 1 Link to comment Share on other sites More sharing options...
m sprank Posted April 7, 2023 Share Posted April 7, 2023 Sounds like the OP wants to swap to use some wheels sitting around. Not a good financial decision. Its not a just change out the hubs and go swap. Link to comment Share on other sites More sharing options...
NORULZleggy Posted April 7, 2023 Share Posted April 7, 2023 50 minutes ago, m sprank said: Sounds like the OP wants to swap to use some wheels sitting around. Not a good financial decision. Its not a just change out the hubs and go swap. Correct Link to comment Share on other sites More sharing options...
