TurboLeg Posted December 15, 2005 Share Posted December 15, 2005 Im a bit confused. I dont know wat the manual button on the auto tranny is for. 1993 Legacy Turbo. any help would be nice Thanks Link to comment Share on other sites More sharing options...
LGTLover Posted December 16, 2005 Share Posted December 16, 2005 OK. so suby makes the "manual" button (technically, the Shift Lock) so that you can start out in second if you want. This is so that you dont spin the tires on snow and ice. It makes it really handy when you are driving your auto really aggressively. You can treat it like a manual. The difference between the Shift Lock tranny and a non-suby auto tranny is that if you are in, say, "2" and you floor it at 10 mph, the transmission will not downshift. The same goes with third gear. When you have the button for Shift Lock on and you are in "D" it acts as like it would without the feature, or with the feature not engauged. Basically, it keeps it in the gear that is selected. Link to comment Share on other sites More sharing options...
TurboLeg Posted December 17, 2005 Author Share Posted December 17, 2005 OK. so suby makes the "manual" button (technically, the Shift Lock) so that you can start out in second if you want. This is so that you dont spin the tires on snow and ice. It makes it really handy when you are driving your auto really aggressively. You can treat it like a manual. The difference between the Shift Lock tranny and a non-suby auto tranny is that if you are in, say, "2" and you floor it at 10 mph, the transmission will not downshift. The same goes with third gear. When you have the button for Shift Lock on and you are in "D" it acts as like it would without the feature, or with the feature not engauged. Basically, it keeps it in the gear that is selected. AHHHHH now that makes alot of sense. I appreciate the time u took man ( or women:icon_neut ) Link to comment Share on other sites More sharing options...
mranlet Posted January 13, 2006 Share Posted January 13, 2006 Just don't downshift at speed while on the gas. Although not as bad as the dreaded Neutral drop, it's still bad for the tranny. Link to comment Share on other sites More sharing options...
TurboLeg Posted January 17, 2006 Author Share Posted January 17, 2006 Just don't downshift at speed while on the gas. Although not as bad as the dreaded Neutral drop, it's still bad for the tranny. That is true. That little manual button really comes in handy with the snow up to your knees!! Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted January 17, 2006 Share Posted January 17, 2006 It is for Manuel. Link to comment Share on other sites More sharing options...
