Fred H Posted July 14, 2022 Share Posted July 14, 2022 The rear bushings on one arm are loose. The car has 107.5K miles and I plan to keep it. I have several questions: 1. Should I replace just the bushings or the arm? 2. If the arm, should I also replace the ball joint? 3. If the arm, should I replace both sides? 4. If both sides, are there some firmer bushings I should consider? I've read what I could find about the Perrins; they seem too stiff for our New England ripples and potholes. But I couldn't find any other alternatives to OEM firmness. Link to comment Share on other sites More sharing options...
darrien917 Posted July 18, 2022 Share Posted July 18, 2022 I would do both arms with the ball joints, it would seem like a lot of work to remove and install only bushings in my opinion. buy oem unless you are taking your car to the track every weekend. I did my FLCA in a parking lot because i slid in to a curb and twisted it like a pretzel lol. Link to comment Share on other sites More sharing options...
Fred H Posted July 18, 2022 Author Share Posted July 18, 2022 Thank you. I was thinking along the same lines and appreciate the confirmation. As I don't track the car I'll stick with oem. Link to comment Share on other sites More sharing options...
Fred H Posted July 26, 2022 Author Share Posted July 26, 2022 FYI, received quotes from my local shop to replace bushings and ball joints in both arms with oem parts. Buying the parts plus labor was $700, buying the arms to reduce the labor was $1,000 (both excluding alignment). With dealer labor rates I expect that the prices would be closer. Link to comment Share on other sites More sharing options...
darrien917 Posted July 26, 2022 Share Posted July 26, 2022 you dont want to do yourself? its very easy and cheapest option! Link to comment Share on other sites More sharing options...
Fred H Posted July 26, 2022 Author Share Posted July 26, 2022 I’m 79; my days of working on cars are past. But I can still enjoy driving them. 1 Link to comment Share on other sites More sharing options...
