dbrbot Posted May 13 Share Posted May 13 As per title really. Has anyone managed to find a set of 16s that fit over a standard gen4 2.0 GT calipers? Link to comment Share on other sites More sharing options...
boxkita Posted May 13 Share Posted May 13 lgt brakes are too big for 16" Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
dbrbot Posted May 14 Author Share Posted May 14 lgt brakes are too big for 16" no 16" in existence that would fit? i've measured it against my wifes standard vw polo 16 inch wheels and a couple more mil and i'd get them over. Must be some fancy rally wheels that have good clearance for big brake calipers... Link to comment Share on other sites More sharing options...
boxkita Posted May 15 Share Posted May 15 lgt brakes are too big for 16". In 18 years, a 4th gen has been available in the USA, no one has posted a 16" wheel that fit. Supposedly xenonk found some based on his post, but wheels were listed. you could always grind the brakes a little, mount the wheels, then grind them a little. Or remove the bigger brakes and install na brakes. curious why it even matters? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
dbrbot Posted May 19 Author Share Posted May 19 Thanks for reply. Only matters because there are loads of bad roads and pot holes here and the more rubber the better. I run 215/50 17s at the mo and they arent bad but 215/55 16s would be even better. However like you say it does look like id be better off staying with 17s Link to comment Share on other sites More sharing options...
