rizzors25 Posted April 20, 2022 Share Posted April 20, 2022 Hey guys I’ve got a 2005 outback n/a auto that has a bit of a rough idle when in drive. When switching to neutral, it’s totally smooth and feels normal. No engine codes or power issues, it seems to cruise pretty good otherwise. I should also note it has a bit of vibration on acceleration only, haven’t checked out yet but a bit of searching seems to be carrier bearing or axles. If that’s the case it shouldn’t affect idle right? Everything looks good and it only has a little over 100k but should I just bite the bullet and replace spark plugs and wires? I hesitate because the neutral idle is so smooth Link to comment Share on other sites More sharing options...
Pleides Posted April 24, 2022 Share Posted April 24, 2022 On automatic cars it's a dead giveaway to me that someone put an aftermarket axle in their car when it shudders in drive but not in neutral. A bad axle will do the same thing. Link to comment Share on other sites More sharing options...
