Spec-Beast Posted March 29, 2022 Share Posted March 29, 2022 Hey all, looking to pick up a an access port for my 06 spec B. I will run the 6 gauge format , but I was wondering two things: 1) What gauges should I run? 2) What are the correct readings for said gauges? Coming from a 7.3 Excursion I'm only used to Boost, EGT and trans temp. I'll be running the stage 1 tune with the Cobb intake as well, if that's important information at all. Sent from my SM-S908U using Tapatalk Link to comment Share on other sites More sharing options...
Pleides Posted March 29, 2022 Share Posted March 29, 2022 The default gauges are usually the best ones to leave up from my experience. Better yet, leave the AP in your glove compartment and drive the car and enjoy it without having to glance at the screen for free anxiety! Link to comment Share on other sites More sharing options...
whitexc Posted March 29, 2022 Share Posted March 29, 2022 Amen to the glove box idea. That AP will drive you nutso. I use it to log and then box it back up. If I was racing or something, that's a different story, in a different car with a different set of gauges. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
blackobxt Posted March 29, 2022 Share Posted March 29, 2022 Yeah put it away. You will be bothered by weird random events that often add up to nothing Link to comment Share on other sites More sharing options...
Max Capacity Posted March 29, 2022 Share Posted March 29, 2022 Yep, both my AP's sit in a box. Drive it and don't worry. Keep your eye's on the road. My wagon has been on Cobb AP since Dec 2004 when it first came out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Spec-Beast Posted March 29, 2022 Author Share Posted March 29, 2022 (edited) That sounds like a great idea. Coming from a diesel in the mountains, my eyes were GLUED to EGT temps. I plan on going Cobb stage 1 and borla exhaust, and call it done. I would hate to bastardize such an uncommon car. Sent from my SM-S908U using Tapatalk Edited March 29, 2022 by Spec-Beast Link to comment Share on other sites More sharing options...
AWDFTW Posted March 30, 2022 Share Posted March 30, 2022 I have: DAM AF correction Boost Feedback knock correction Fine knock learn Coolant temp Link to comment Share on other sites More sharing options...
