1-3-2-4 Posted March 5, 2022 Share Posted March 5, 2022 (edited) I got my wife one needs a little bit of TLC First up are the codes it’s a automatic The ABS is showing the rear left and right open circuit or shorted.. last I remember when I had my ‘05 GT the sensor was just bad. Now the other codes… P0137 P0851 P1152 P1153 I think the P0851 is what’s causing a low idle? And I don’t understand why the car cycles the fans when it’s turned to on.. I’ve only seen this with like the test connectors plugged in but unless I missed another set of plugs… https://youtu.be/N3h9hf1sfKQ Edited March 5, 2022 by 1-3-2-4 Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 5, 2022 Author Share Posted March 5, 2022 I know the car has green test connectors on the side driver side dash in the panel but anything else under the dash? My service manual is on my desktop of packed away. Link to comment Share on other sites More sharing options...
Infosecdad Posted March 5, 2022 Share Posted March 5, 2022 There are a set of green connectors in the passenger footwell. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 6, 2022 Author Share Posted March 6, 2022 There are a set of green connectors in the passenger footwell. I remember that from my LGT but I didn't see any.. now I heard they are up under the dash on the drivers side which I'm going to check in a few. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 17, 2022 Author Share Posted March 17, 2022 Ok so The only code that came back is the p0171 and now the new code under load was the p0301 and p0303 Link to comment Share on other sites More sharing options...
Pleides Posted March 20, 2022 Share Posted March 20, 2022 It sounds like a bad O2 sensor or a bad catalytic converter. Might cause the misfires. Are you running super rich or lean? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 17, 2022 Author Share Posted April 17, 2022 Little update is no more CEL codes but I changed both front and rear sensors plus the MAF sensor but I think I could of got by on not having to change that. Link to comment Share on other sites More sharing options...
