NY: 2009 Legacy Spec B 150k $8900
Bioya
2009 Legacy Spec.B
Price: $8900
Mileage: 150000
Transmission: 6MT with STI front differential
I'm selling my '09 Spec.B. I really enjoyed this car and it was my daily for almost 10 years. I bought a '13 Sti hatchback, so this one has to go.
Engine- Short block replaced at +/- 80k with factory Subaru short block with Manley "turbo tuf" forged pistons. At that time TGV and air pump delete was performed. ID1000 and VF52 installed. Car has aftermarket silicone intake. AVO intercooler. Some catless downpipe. Cobb accesport (2.0) Timing belt/water pump/oil pimp/pickup replaced with engine.
Trans- When the engine was out the open front differential was replaced with a helical STi front. The flywheel was upgraded to a STi sized unit and a Cryo treated South bend clutch installed. The trans has a Kartboy Spec.b shifter with the assorted bushings.
Suspension- Koni "yellow" single adjustable struts with King lowering springs. Whiteline front and rear sway bars. I do have the stock struts/springs and sway bars. (65k miles give or take)
Brakes- 08 STi brembo front/painted 04 rear with the oversized rear parking brake shoes to allow use of 04 (5x100) rotors. Stainless braded brake lines.
Wheels- 18x8.5 Enkei touring Raijin wrapped in 235/40R18 Michelin pilot sports. Tires are worn.
Body- Normal dings for a 12+ year old car. Paint shines up well. Rust on passenger rear wheel well arch in the "normal" spot. Rust chip on upper windshield edge over drivers side.
I'm sure I'm forgetting things.
Link from when I bought the car in '12, mods have changed.
https://legacygt.com/forums/showthre...ld-187813.html
Current Photos, I will try and take more
https://photos.app.goo.gl/Lu1VSQDE5CdCQQMD6
PhHmuP5e2yzKKe9D8
Edited by Bioya
