SVeer Posted December 7, 2005 Share Posted December 7, 2005 I'm gonna be going to the Parts Pull place to get one of these and I need to know where it is. I have a 95 Legacy 2.2LS .Well if anyone can be nice enough to help me that would be great. PS Is this module the same as the dimmer relay? Link to comment Share on other sites More sharing options...
low_suby_wagon Posted December 12, 2005 Share Posted December 12, 2005 The illumination control module is located in the drivers side under dash panel under the steering wheel. it is at about the 7 o'clock position under the steering wheel. remove that cover and you will see it. I don't recall it being called a dimmer relay. They are 2 seperate parts. I don't even remember the leggy having a dimmer relay. Just a big fuse under the hood for illumination used as back up for the one inside. Link to comment Share on other sites More sharing options...
