ddub Posted December 7, 2005 Share Posted December 7, 2005 tape. I didn't see this mentioned before as most people seemed to believe it was for sat/aux or something. This from the euro spec B http://legacygt.com/forums/vbpicgallery.php?do=big&p=848 from: http://legacygt.com/forums/vbpicgallery.php?do=view&g=432 ________ Glass Weed Pipe Link to comment Share on other sites More sharing options...
dralston Posted December 8, 2005 Share Posted December 8, 2005 On the USDM stereo it say SAT on the circuit board. The button is the there and everything. The only thing stopping you from pressing it is the plastics. Also if you look at the display you can see that there is a SAT light (It may be hard to see in the car because the face is tinted). I've taken apart a stereo because I'm working on cutting it in half so I can install a double din. Link to comment Share on other sites More sharing options...
LivNLegacy Posted December 8, 2005 Share Posted December 8, 2005 I've taken apart a stereo because I'm working on cutting it in half so I can install a double din. http://www.acurazine.com/forums/images/smilies/screwy.gif just kiddin' http://www.acurazine.com/forums/images/smilies/bow.gif good luck my friend... If you can read this, you're following too close. Click Me Link to comment Share on other sites More sharing options...
ddub Posted December 8, 2005 Author Share Posted December 8, 2005 Yes, I've seen the SAT light on the stereo faceplate. I thought that since everything else seemed the same with the stereo I linked to, that the stuff behind the screens would be the same too. It would be interesting to see if a stock stereo system with the tape player had the same 'SAT' printed on the circuit board. If so, the word SAT doesn't mean anything (at least for how subaru uses this stereo). Thanks for the info on the circuit board. And good luck ________ Buy Silver Surfer Vaporizer Link to comment Share on other sites More sharing options...
