JDM Trailing arms
ktm200
In the process of going through and refreshing my suspension. Have a set of JDM front control arms on the way and I'm going to stuff new bushings in them. I also found a set of JDM Spec B aluminum rear trailing arms, uppers, and rear control arms that are supposedly low mileage (40k or so). Was thinking for the cost of changing out all of my OEM bushings, I could go with the JDM Spec B arms, and likely not have to swap out too many of the bushings. Easier and less downtime to just swap in the pre-prepped arms.
Question though, is there anything unique about the JDM rear trailing arms compared to USDM? I know I'll need the longer hub bolts, but are there any other odd differences that anyone is aware of? ABS sensors the same between the USDM and JDM?
Appreciate any input.
